A month or two ago I noticed that, when my 2017 X was not being driven, unless I was sitting in the drivers seat and had pressed the brake pedal the window controls did not work.
In other words, if I walked up to the car with my fob on me, opened the door and tried to raise/lower a window the window would not move (in that scenario the drivers display shows ”Car Off”). I have to sit down, press the brake, the “Car Off” message is replaced by the PRND display, and then the window controls work.
Also, if I have sat down, pressed the brake, lowered a window, get out of the car without closing the door and then try to raise the window the window won’t go up; the window controls don’t work. In that scenario the car almost immediately goes into the “Car Off” state after getting out of the drivers seat and the windows don’t work.
I’ve owned the car for 5 years. My wife and I are sure that in the past the window controls worked as soon as we walked up to the car and opened the doors. As long as the car detected a fob was present, the windows could be operated. For example, when I was washing my car I could at any time open a door and raise/lower windows as desired long without sitting down and pressing the brake pedal.
I have re-booted the car several times but it makes no difference.
My 2017 X is currently on 2021.24.28
Anyone else having this issue? Thanks.
