Change in Watts/mile with wider aftermarker wheels?
Discussion in 'Model S: Interior & Exterior' started by rdalcanto, Feb 6, 2015.
  1. rdalcanto
    rdalcanto Member
    Salt Lake City
    Those of you have have gone to 20 inch wheels and put 275 or wider on the back, have you noticed a significant loss in range?
  2. Kofi
    Kofi Member
    San Jose, CA
    Your range could slightly increase by going with a lighter, stronger 20" setup. In our experience the optimal rear size is 285/35/20 for staggered fitments.
  3. rdalcanto
    rdalcanto Member
    Salt Lake City
    How is the inner side tread wear on a 285 tire? I can't believe how much better my 245 snow tires wear compared to the 265 PS2s. I'm sure part of it is the rubber compound, but I wonder how much is the width? Thoughts?
  4. jerry33
    Texas
    Did you do an alignment when you put on the winter tires?
    Whether you did or not, it's pretty obvious that at a given amount of camber angle the difference between the inside and outside edges of the tire will be more with a wider tire, which will emphasize any misalignment (particularly toe). In addition, the 19" winter tires have a much higher sidewall and winter tires will have a much more flexible carcass ply and belt structure than summer performance tires. The more sidewall height there is, the less sensitive the tire will be to toe combined with camber. My opinion is that the "rubber band on a wheel" that the tire, wheel, and car manufacturers want to provide is the most costly and silly bit of fashion that's ever affected car design. It's great for their profits and bad for everything else.
  5. Kofi
    Kofi Member
    San Jose, CA
    You can run a rotatable setup with 245/40R/20 in the front and rear. This should extend your tread life longer than a staggered setup. Running a 285 in the rear optimizes grip, handling, and looks awesome on the car.
