New to the forum here. looking into getting signature wheels with 265/35-19 PS4s With the wider tire it is best to run lower pressure. But that will trigger a TPMS alarm is there a way to lower the setpoint to say 32 to support the lower pressure in the wider tires? thank you Jim
Yup you can, see the 'Manually Resetting TPMS Sensors' section of the manual under Tire Care and Maintenance. Says "To do so, touch Service > Reset TPMS Sensors and follow the onscreen instructions." Btw - i have 265 tires and even running at 36 psi means pretty bad efficiency, i normally stay around 39-40 PSI.
I had been wondering what pressures to use on the Michelin 245 A/S3+ I now run on Signature 19 inch wheels...
