Hi Folks,
Not an expert so this is a newbie question, what would happen if you had a new set of front/rear gears cut that changed the 9:1 ratio to 12 or even 15:1. I know you would loose top speed but who uses that? Perhaps the power curve is already maximised at 9:1 and you would end up with less speed over the 1/4 mile due to losses at the higher rotation speed of the motors vs speed that this would cause. Perhaps also the stub axels would simply twist off :-0
Just a thought
Terry
Just a thought
Terry
