Changing mph central display?
Discussion in 'Model S: User Interface' started by Asciidv, Apr 4, 2016.
  1. Asciidv
    Asciidv Member
    Ponteland, Northumberland, England
    On many Model S YouTube videos the central MPH display is different to mine (2016 Model S 90D). Is the display changeable? I know that the side displays are easily changeable using the scroll controls but I have yet to find anything to change the main MPH display. I know I must be missing something...
    Thanks in advance.
  2. swaltner
    swaltner Active Member
    Kansas, USA
    Working on the assumption that you're using the 7.x firmware, you're seeing the UI change that was implemented between firmware 6.x and 7.x. Many people have complained about this UI change, particularly those with cars that lack the AP hardware since the UI change seemed primarily focused on the autopilot features.
    As of now (7.1 firmware) there is no way to revert back to the classic format of the central display on the instrument cluster.
  3. wayner
    wayner Active Member
    Toronto
    But you likely could change from MPH to KPH!
