A few similar threads on main site, but recommendations too US centric. So...
Got some winter wheels to go on at some point. I normally swap wheels no problem. But Model 3 comes with no wheel changing kit, is pretty heavy at around 2 tonne (although we previously had a cough, heavy VW Passat Estate diesel, cough...) and has 129 ft-lb torque (175Nm) on wheel nuts. So having to pretty much start from scratch as much of what I already have is below spec.
My current torque wrench is 110 ft-lb and trolley jack is probably 2 ton and possibly too tall. But both will be at least 30 years old.
I have an 1150kg scissor jack from the Passat that I may be able to modify to work with my jack pads, but I'm not happy with angle jack might follow during lift. Plus 1150kg is close to 50% car weight.
So far I have bought a new 21mm air impact grade wheel nut socket.
I have a Dewalt impact driver that I need to check spec of, but think it may do max 125 ft-lb torque so pretty close. I have no hex to 1/2" drive converter though. However, not used impact driver on wheel nuts before and know this thing can be vicious when driving big screws. Plus how do I know its really done 125 ft-lb?
So I think I need
Ideally, I would like solution to be portable and possibly be used remotely incase of puncture. An off season wheel can be used as an emergency spare.
I would rather not pack up 4 wheels into car twice a year and pay £30 for tyre fitters to swap when I can do the job myself with the right kit.
So I think I need
- Breaker bar - length? 24"?
- Torque wrench or something else?
- Possibly a 1/2" socket extender.
- Jack? 2 tonne low profile trolley? Would like to find a more compact alternative.
- Something to store the wheels without resting on the tyres? - 700mm diameter, 245mm width each wheel. I saw a nice vertical trolley stand but at 225 width, too small. Seen I think a bigger one on ebay but gets flimsy reviews. Or I could just stack and store on the pallet they came on.
