I've a black model X on order and went for the smaller 20" wheels (slipstream I think they're called). I'm not sure if they're bigger at the back or not.
I want to change them to diamond cut wheels. Can anyone please help me with the following:
1) Are the current model X with 20" slipstreams wider on the back?
2) And if so do I ideally need to be buying the same staggered wheels or doesn't it really matter if I just go the same size?
3) Does the wheel width of the new wheels have to match what the TMX ships with? Will it affect handling/performance/safety if I get it wrong?
4) If I get identically sized wheels will I be able to just swap the tyres over?
5) This TPMS thing - is it something that comes in the wheel or the tyres. If tyres I suppose I'll need to keep the tyres. If wheels I shouldn't change then?
6) As the TMX is so heavy should I be buying a certain grade/strength of wheel so it doesn't buckle under the weight?
Thanks in advance to anyone who can answer any or all of the above!
