we loose power for the entire house
Hokay. So it sounds like one of a few things.
- You have a seriously overloaded breaker panel. Modern houses get 100A to 200A service these days; but I've seen breaker panels rated for 60A or less. I take a flying guess and suggest that your HVAC system plus 32A from the mobile connector pops the breaker. Since most HVACs are 20A or less.. that's not much of a breaker panel?
- The main breaker is something like 100A, but it's old and damaged. It happens. You need a new one?
- You're in Maryland, I think. Um. A few weeks ago I was corresponding with somebody down there on these here forums and, for whatever reason, was doing a contrast-and-compare between NJ's ideas about how to encourage automotive electrification and Maryland's. If my memory isn't shot (and it probably is) I think that Maryland had subsidies for certain things regarding home electric car charging, and I think one of those subsidies was for getting a heftier house power cable laid in for those whose house electrical might be found wanting.
There are lots and lots of other possibilities. Older houses are known to have sub-panels, kind of like suburbs of the main panel. Sub-panels are typically hooked up to a breaker on the main panel. Not sure if this is your issue or not.
Friend of the family used to live in a house down in Maryland; moved out in the last year to a smaller place. I had a look at the breaker panel in that house at one point. It had, like, twenty slots, and had maybe one open place for a breaker. Your place like that?
While I don't use the feature (I have a wall connector on a 60A breaker), there's supposed to be a feature in the charging menu of the car where, at a particular
location, one can set the charging current to some arbitrary value. I've seen it on both the Model Y and Model 3 menus. I find it odd that you don't have it on your car. But since you're talking about popping the main at 3 a.m., I kind of wonder what, exactly, was going on. A/C cycling?
Finally: There's this thing electricians do when installing high-power outlets, be they NEMA14-50, Wall Connectors, clothes dries, or whatever: They check to see if it's likely that, with the new load, whether or not the load on the panel will be exceeded. Competent electricians won't overload a panel. Fly-by-nighters without forwarding mail addresses or real names will. Further, electrical building inspectors get really bent out of shape by that kind of thing.
And there's serious reasons for the above. Contrary to popular opinion, breakers are designed to do the save-your-life-and-that-of-your-loved-ones jig. Get an overcurrent, they pop. They might be expected to pop a few times in their lifetime, when shorts or Other Evil occur. What they are
not designed to do is casually pop because somebody left the toaster oven on and somebody else turned on the coffee maker. Because breakers can fail.
If a breaker fails open, that's one thing, and there's a lot of cursing because Stuff Won't Work. But breakers can fail short, too, and that's just evil. Because when too much stuff for the
wire gets turned on, the wires get hot and, and I am NOT joking here, stuff can catch on fire. Like your house.
Usually, when we're talking about a breaker and the wire going into it, the wire and the breaker are sized to match. Got a 50A mains breaker? Then the cheapest wire that works is wire that's rated for 50A, max. Run 60A or 100A through that wire because the breaker is seized up, closed, and House Fires R Us.
If it's just you in that place, then, well, you're allowed to immolate yourself. But if you've got nearest and dearest there as well, you'd be risking their lives. Do they know that?
Sorry about the lecture, but I've seen several cases of poor wiring that coulda killed people, so it sets me off.
