Charge limit exceeded AFTER disconnecting
Discussion in 'Model S: Battery & Charging' started by MarcG, Jun 24, 2015.
  1. MarcG
    MarcG Active Member
    San Francisco
    I set my daily charge to 90% and usually plug in every two or three days at work during the week. Today, I charged from a little under 40% (92 miles of rated range) to the usual 90%, which got me to 225 miles. Charging stopped by itself, and VisibleTesla confirmed I was a 90% and 225.02 miles of rated range.
    After a few minutes of getting the notification of charge completion, I went out to the parking lot to unplug. After unplugging from the charger, I got in my car and immediately noticed the car reported 227 miles of range... "strange" I thought, the only time range goes UP while stationary is when I change RANGE MODE from ON to OFF - however, I've kept it ON for several months now.
    I then opened the charge status page by tapping on the battery icon at the top-left of the screen, and sure enough: the battery level was OVER 90%, with the line showing the current capacity to the right of the caret indicating charge limit, which was directly under 90%. Unfortunately, I didn't have my phone on me at the time to take a shot of that screen.
    VisibleTesla confirmed my suspicion: the battery level showed 91% and the rated miles was at 226.72, up from 90% and 225.02, respectively. Also, the graphs do show an increase in rated range several minutes AFTER current and voltage dropped to 0.
    Glitch in the charging system, or firmware/software bug?
  2. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    got that message too for the first time last week on my road trip
  3. rlang59
    rlang59 Member
    US
    When did you end up upgrading to an 85?
  4. Kalud
    Kalud Active Member
    Montreal, QC
    My guess is that its temperature related. Remember that the miles and SOC% values are estimates, its not like measuring or weighting something. There is a software algorithm that makes an estimate based on current battery voltage, past draining curve while driving (miles driven with power consumption vs voltage drop over time).
    So my guess is that the car charged to 90% (100% in the case of islandbayy) then stopped. Some time later the algorithm adjusted the % value (and rated range) above the 90/100 % because probably of a temperature related effect of voltage and it triggered the message. Tesla might adjust that trigger to increase the threshold if it happens frequently...
  5. ra-san
    ra-san Member
    San Diego, CA
    It didn't change much. I'd just regard that as chemistry settling. I haven't noticed it yet on the S but that sort of thing often happened on the roadster.
  6. sorka
    sorka Active Member
    Merced, CA
    I think all it means is that the SOC ended up being higher than what the limit was set to. It could just be a software glitch. I doubt it actually means anything.
  7. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    That's what I was going to say.
    I can't even get them to put in the cold weather windshield.
  8. qwk
    qwk Model S P2681
    I have noticed this too. What's up?
  9. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Something similar happened to me a few months ago. I would charge to a certain level, say 228 miles or 90%. Then, when I turned on pre-cooling, the range went up by 3 miles to 231 miles, simply by pre-cooling the car. It did that for a while - couple of weeks - but the behavior eventually stopped and I can no longer reproduce it.
  10. mknox
    mknox Well-Known Member
    Toronto, ON
    I have seen the same behavior once or twice, but I believe it has only happened with the most current firmware I'm on right now.
  11. MarcG
    MarcG Active Member
    San Francisco
    What version is that?
  12. mknox
    Toronto, ON
    6.2 (2.4.239)
