Charge Limit Revert back by itself to Pre-Software Update Setting
ANDREWG68
New Member
Jul 19, 2020
4
0
New Jersey
Hi everyone,
Looking for some help with a problem I've been having. I recently just received the 2020.24.6.9 software update on my SR+ and afterwards, I've had a strange problem with the charge limit setting for the battery.
I had it set to 80% before the update, but now, whenever I set it to a different level, the car will change it back to 80% within a few minutes while it's charging. i.e. set it to 90% before a trip and it starts charging, but car drops the setting back to 80% by itself and stops charging the vehicle from the wall charger.
Has anyone else had this type of issue before and any suggestions for what i can try?
I've already powered the car on/off a few times in hopes of clearing the error, but it still persists.
Thanks!
ANDREWG68
New Member
Jul 19, 2020
4
0
New Jersey
I tried it 3 times (reset with two steering wheel thumbsticks and set new charge limit ~85%), but it will charge about ~1-3 minutes and then stop again when the charge limit goes back to 80%.
ANDREWG68
New Member
Jul 19, 2020
4
0
New Jersey
Hi everyone, thanks for your suggestions. I'm still not sure what might have been causing the issue, but I reset my Tesla password, logged back in the app and was able to charge it up to my 90% limit again without the setting changing by itself.
jjrandorin
Nov 28, 2018
7,197
7,979
Riverside Co. CA
Did you ever, at any time, try any of the third party apps like "stats" or "Teslafi" or any other application that interfaces with your tesla like something that interfaces with a watch or anything?
Since it stopped when you changed your password, that means something other than the tesla app was authenticated and changing settings on your account. If you never did that, maybe someone with access to your car did... but that is the only way that changing your password would make it stop. If you dont know what that was, you should investigate.
Hilgi
19
5
South Jordan, UT
I did that update and now I get clicking when I plug in at home and it says, "Limited charging Charge Cable may not be plugged securely into the vehicle. The Tesla logo is also flashing yellow. I am getting 16/24 amps now.
