SomeJoe7777
Marginally-Known Member
Well, that's the power dissipated across all the wiring, not just the HPWC handle/plug. Still if your plug is dissipating that much power continuously you will not be able to hold it, just picture an 80W incandescent bulb.
I would like to know if Tesla service cleans and inspects the UMC plug/car receptacle as part of regular maintenance visits as I have not seen that on the service summary.
Yes, you're correct in that those numbers represent the total power dissipation over the entire wiring between the measurement points (one in my breaker panel with the TED meter, the other in the car at the battery terminals). However, we can assume that most of the resistance is at the connection points in the breaker, HPWC contacts, charge port, and charger HV box in the car.
My HPWC handle had been getting quite warm during charging sessions so I assume a fair amount of power was being dissipated at the charge port connector.
To my knowledge, I don't think that Tesla cleans the charge port during annual maintenance, and they absolutely should. However, that's only part of the maintenance that needs to be done. The HPWC, UMC, and Chademo adapters (if you own one) should also be cleaned, but UMC and Chademo may not be in the car, and HPWC certainly won't be.
