Charge port color staying off
Discussion in 'Model S' started by ccharleb, Jun 27, 2017.
Tags:
  1. ccharleb
    ccharleb Member
    Montreal (QC), Canada
    Updated to 17.24.28 a few days ago.
    If I plug and start charging the car, I do have the green blinking ring.
    If I go away, and return to my car later on while it's still charging, even when I unlock the doors, the ring stays black??
    Usualy, it would stay black until I unlock the doors, then I would see the green ring blinking.
    Thanks!
    Christian
  2. SomeJoe7777
    SomeJoe7777 Marginally-Known Member
    Houston, TX
    Ya, I'm seeing this behavior as well. Not sure if this is a bug or an intended behavior change.
  3. JohnnyG
    JohnnyG Weee!
    Columbus, OH
    ditto...
  4. RichardD
    RichardD Member
    Texas
    If you press the button on the charger does it wake up?
  5. SomeJoe7777
    Houston, TX
    Pressing the button releases the charge port lock, the ring then lights up white and you can remove the charging plug. It's as if the command to light up the ring in green upon vehicle unlock is missing, but otherwise there's no change in operational behavior.
  6. BoldSharpe
    BoldSharpe Member
    Wisconsin
    Same here since the update; I'm indifferent on the change.
    I've also noticed triggering the charge port release (white light) is now almost instantaneous after I press the connector plug button whereas there was a minor delay previously. I've found this to be a great little update as the functionality was quite finicky before.
