Charge port door won’t fully close?
bigboost
168
99
Sarasota, FL
Anyone have issues with the charge port door not closing all the way? Mine will close electronically about 70% of the way, then has to be manually pushed in to close, however, it doesn’t close flush and it can then be manually pulled back open.
What’s the deal here? My X is only 2 months old and it just started doing this
Thanks!
P85_DA
4,171
2,880
Thanks!
Have them replace port should close flush
bmanke
74
28
Chesapeake, VA
Our charge port does not close on our brand new X. It hangs up / hits on the tail light. If you push it while closing its ok. I guess if the service center had done any sort of pre delivery we wouldn't have been there for 4+ hours but I won't get into that rant. And we are Tesla fan boys and girls with our third purchase.
Reactions: P85_DA
dgatwood
793
874
Sunnyvale, ca
Thanks!
Mine started doing that after a few weeks. Tesla swapped out the whole charge port assembly, and it hasn't recurred. Time to take it in for service before the rainy season starts. :)
jboy210
4,955
3,033
Northern California
Thanks!
Mine had this exact issue. It means the door it not aligned correctly. Take a look at it as you manually push the door. I suspect you will not that the door is hitting the upper or lower portion of the cutout.
I did a mobile service and had them fix it at home. The Ranger came to my house in his Model S. He removed the interior panels by the charger and realigned the door. Total time was 30 minutes. Great service!
In thinking back on it, I may have caused the issue by hitting the door with the charge connector.
kak1154
40
42
CT
Yeah, mine started doing that, too. I'm just dealing with it for a while until I have a larger reason to visit the SC.
Reactions: Maaz
GalaxySurfer
Life, The Universe and Everything.
Oct 10, 2018
229
134
Oregon
My X was built in august 2018, just started happening to me 3 days ago. Luckily i have a SC appointment soon for the new security upgrade.
RichRediker
New Member
Aug 7, 2018
US
Mine was fixed by the mobile service tech. He said he had to adjust the space between the edge of the port door and the car. It has been perfect since.
bayx
489
210
San Francisco
Mine started doing this since last week, it would not close fully and remained open half way, won't close manually either. The only way it would close is by hooking up the charger again and removing it. And then it stopped doing it this week! So random!
caesartheday
63
112
Santa Clarita, CA
Thanks!
Mine wouldn't close and I had Tesla "fix" it 3 times. It would close but after about 2-3 weeks the latch would continue to stick out. Finally when I took it to the SC, they shaved off a little tiny bit of plastic on the hinge and apparently that fixed it permanently. I've heard it's a known issue for many of the March 2018 Model X's...fixable but you have to specifically tell your technician to deal with the little plastic hinge.
