Charge Port Issues
Oct 10, 2019
245
115
So-Cal
So over the last few days my charge port has been acting more and more strange.
First it wouldn't unlock the plug unless I double apped he key to unlock the car even though the car was already unlocked.
Then yesterday it took a few pushes of the charge port handle button to get the lock to go down so I could insert the plug. And at the same time the port is not lighting up any color at any time.
I know where the manual release is and how to work it, I'm concerned that if I have to use the manual release it won't let me insert the charger as it's intended as a removal of plug lever.
It is still charging for now, but tomorrow I have a 450 mile trip to get home and I'm hoping to not get stuck at a SC unable to charge since the nearest service center will be about 500 miles in any direction during my trip.
Is my charge port going out? If so is that a part tesla will sell me to replace, or will they be assholes and force me pay for them to replace it?
Or is there something I can test and/or replace to get it working right?
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,396
8,543
Colorado
I noticed some weirdness with my Model S charge port with the last firmware version or two. At first, I thought it might be related to the colder weather but now I'm wondering if it is a software issue. Coincidentally, there was mention that the button to the left of the charge port was finally activated a few weeks back. Most people never knew there was a button there. When we were on a road trip earlier in December, there were three occasions when I couldn't plug in at a Supercharger. I tried using the button to the left of the charge port and it retracted the pins and then I was able to plug in as usual.
Oct 10, 2019
245
115
So-Cal
I did just get an update a couple days ago, I can't remember it it was being funny before that or not.
Also button? There is a small grey lever/switch on the inside bottom that retracts the lock. I've never seen any button on the side of the port.
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,396
8,543
Colorado
Oct 10, 2019
245
115
So-Cal
Yeah no button there, must be some new fangled hoopla they put in the newer cars I guess.
And update, I made it home fine all 3 SC that I use when I pushed the button on he SC handle it opened the port door like it should but the lock didn't go down. However, I poked my finger in here and pushed the lock and it retracted automatically and then I inserted the charger and it worked fine and removed properly and easily. No lights at all during all charges, but now that I'm home charging at 10A 120v the lock still didn't retract without me pushing it but now my green flashing light is back.
Could the locking mechanism need lubrication of some sort, if so how does one go about doing that safely and what type of lube should I use?
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,396
8,543
Colorado
What year is your S? Our early 2017 has it and both 2016 had it as well. It might've been around since the powered charge port hatch was released.
Oct 10, 2019
245
115
So-Cal
Well how about that it is a button. It looks like a rubber bumper for the automatic door and that's what I always attributed it as.
BTW mines a 2014 P85D
Today I went out here and it's still green and it changed to blue then white like it is supposed to for the unplug process. So I'm not sure WTF is going on with the charge port.
Oct 10, 2019
245
115
So-Cal
So i think the charge port is about to take a *sugar* on me. every time i get back in my car the screen has the charging screen displayed like it would if you opened the charge port door but the door wasnt opened. And it's getting to like 80% of the time i have to play around with the lock in the port with my finger to get it to go down.
Is this a part i can just get from tesla and DIY? or will they make me pay for them to swap it out? anyone know about pricing for something like this?
Oct 10, 2019
245
115
So-Cal
Well i went to the SC and they installed a new charge port door. Assholes made me pay $100 for them to install it when i could've done it in my driveway. Apparently its considered a HV part and fall on the restricted parts list. part was only $80.
Its been like a week now and no issues since it was changed out the door and the charger all working like they should be.
shieldsbrown
20
0
Ontario, Canada
I have a different problem related to the charge port. I have a 2015 85D. The charge port door is motorized.
My problem is getting the charge port to unlatch after charging has stopped. The manual says to press the button on the charge handle (it says nothing about the button on the left). When I press the button on the charge handle, nothing happens. I tried using the phone app to unlatch the port, and it works, but almost immediately re-latches. So fast that I can't reach for the handle quickly enough to pull it out.
The only way I can get the port to unlatch is from within the car, using the touchscreen.
BTW - the button on the charge handle works correctly when opening the charge port door, and there is never a problem getting the charge cable to lock in place.
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,396
8,543
Colorado
What happens when you use the button on the left of the charge port? I needed to use it four times in December and it unlatched the plug for me or retracted the pins and allowed me to insert the plug.
Oct 10, 2019
245
115
So-Cal
Mine is motorized to on my 14. There is a manual release button inside the trunk onnje back of the charger. But it sounds like your charge port or the door is going bad also. Have you gotten any errors coming up on the MCU about it?
When you push the botton on the charge cable how long do you hold it? When I go to unplug sometimes I have to hold the button for like 3-5 seconds for it to disengage charging then unlock itself.
Reactions: Rocky_H
shieldsbrown
20
0
Ontario, Canada
Well, this is embarrassing! After writing my complaint yesterday, I tried using the charge handle to unlatch the charge port today. And it worked as intended! Doh!
I don't believe I did anything different from previous tries - but today it worked, twice.
I will monitor and report back if it fails again.
thanks for your interest
Jim Brown
