  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Charge SR to 100% every time?
I was wondering how much % I should charge my SR.
It is downgraded from SR+, so 100% in SR now is actually just about 90% to the original.
Will charging 100% in this SR every time be ok?
if you charge at home every night, and don't commute across state lines every single day, no need to charge that high. Charge to 80 and only to 100 when taking a long trip.
I charge to 100% nightly on my SR. It is supposed to be top locked which would mean that is fine to do and would be like charing it to 90% ish based on the batteries actual capacity. There have been plenty of times we had a decent amount of stuff to do or went to a park a little ways away and were close on available range. I just keep it charged to 100% in case we need the range.
How do you know it's not "bottom locked"?
Previously posted comments by SR owners who charge to 100% state, that regenerative braking is not limited at 100%, like it normally is for all non software-locked models. This heavily implies the SR is top locked, and not bottom locked.
Bottom locking might also interfere with the BMS re-calibrating or re-balancing the batteries, which requires low charge levels to work.
There's also an interesting paper posted in the battery/charging section of the forum, which states that low charge levels are necessary to self heal cracks that form when nickel cathodes are under strain from being charged to high levels. This applies to high nickel content (above 0.8 ratio) cathodes, which the Model 3 probably does use.
I am charging 100% right now, every time but not charging every day.
One of my major concern is that just in case the battery goes bad, within the warranty, would Tesla refuse to replace/repair because I charge 100% every time? Even though it is an SR downgraded from SR+?
mswlogo
8,356
7,872
MA, NH
Good point.
But I would think bottom locking would be better for BMS re-balancing. It appears to do the heavy duty re-balancing when it gets to the top of a true full battery.
What it should probably do is "stagger" the usable window ;)
ecarfan
Moderator
There is got to be a way to get cell voltage read outs from the car in some debug mode or something?
Yes, Tesla Service has access to that sort of information but Tesla owners do not. Which makes sense from Tesla’s point of view: they don’t want to deal with obsessive owners pestering them with questions about the exact state of charge of individual cells or groups of cells.
Reactions: MountainPass
apart from mswlogo noone here really gets the OPs question.
You should read the replies more carefully.
That's just a hostile consumer outlook. That's how anti right to repair laws get passed.
  • Disagree
Reactions: Common_Loon
I’ve always wondered whether Tesla intentionally refuses to disclose how the battery lock in the SR works or whether they just don’t have anyone in charge of communicating these things. Just like the question of whether the motor in a Performance car is different than a non-Performance. Does Tesla really want to keep these things secret or are they just really bad at communicating?
SlimJim
1,015
1,034
I will test this tomorrow morning.
I will charge to 100% tonight and see if regen brake works tomorrow.
ucmndd
9,468
18,378
Yes you can charge to 100%, every time, with impunity.
Yes, we know for certain the battery is top locked. There’s a thread documenting/confirming as much in the battery/charging section - if you want to try and find it by sifting through all the mindless droning on and countless duplicate threads about battery degradation, be my guest.
Yes, you’ll find lots of opinions on this subject. Most of them are bullshit and introduce false fears and claims that known things are unknown.
Charge to 100% all you want, it’s exactly the same as charging your physical battery to ~92%.
