I know to charge it to 100% before the road trip but do I leave it on 100% during the road trip and change it back to 90% once I get back home? Thanks
Depends on supercharging spacing. You don't want to leave the pack sitting at 100% for a while. If you are staying the night, charge to 90% then raise the charge limit remotely before you leave.I know to charge it to 100% before the road trip but do I leave it on 100% during the road trip and change it back to 90% once I get back home? Thanks
Exactly. Set st at 90% when you arrive at the hotel and then use the app to set it at 100% when you wake up.If I know I need 100% charge before I leave while plugged into destination charger (eg at 48A), I charge to 90% overnight and then about 90-120 minutes before leaving, set to 100% and top up before I leave. That way I know that the vehicle is not sitting around at 100% for long.
I tried to set the charge limit to 100% whenever we were starting from home, stopping for dinner, or were delayed enough in a mall that it was going to pass 90% before we made it back to the car. It just saves a little time at the next charging stop, or maybe eliminates a stop. When staying overnight (or at home) I charged to 90%, moved the X to a regular parking spot, then moved it back in the morning, set the limit to 100%, and ate breakfast. That avoids leaving it sitting at 100% all night.
Only problem was back at home I forget to reset the limit to 90% and ended up at 100% about 1 AM and nowhere I needed to drive.
Note that the Trip planner also respects the charge limit that you set. So if you want to limit how long you spend at each supercharger you can set a low limit like 80% to reduce the amount of tapered charging time. And if you’d like to limit the number of stops you can set the limit to 100% and the system is more likely to plan a 50 minute stop suitable for a relaxing meal.
If you leave it set at 100% for three days you will get a message on the screen reminding you.Only problem was back at home I forget to reset the limit to 90% and ended up at 100% about 1 AM and nowhere I needed to drive.
I did this once too. I just remembered at 1am that I still had it set to 100% and when I checked the app, it had just finished charging to 100%. Duh! So, I did what any Tesla nut would do. Got out of my PJs at 1am and drove the Tesla for 20-30 minutes to get the charge back close to 90% before heading back to bed.I tried to set the charge limit to 100% whenever we were starting from home, stopping for dinner, or were delayed enough in a mall that it was going to pass 90% before we made it back to the car. It just saves a little time at the next charging stop, or maybe eliminates a stop. When staying overnight (or at home) I charged to 90%, moved the X to a regular parking spot, then moved it back in the morning, set the limit to 100%, and ate breakfast. That avoids leaving it sitting at 100% all night.
One place I'm hoping Tesla gives up some help in future firmware - they could easily put in geotagged "home" and "away" default charge limit settings in for us, so you can have it automatically set the limit back to 80% when it detects that you're charging at home again.
Or maybe generic geotagged - you set the limit as you're charging, and it prompts always charge to this limit at this location like the suspension changes or the door opening - helpful for folks who charge at work daily too.
seems like this app is only for Android phonesget the app 'Dashboard for Tesla'
What you suggested is the way to go! Smart-Full-Charging, or something like that. To avoid mistaked 100% cases.One place I'm hoping Tesla gives up some help in future firmware - they could easily put in geotagged "home" and "away" default charge limit settings in for us, so you can have it automatically set the limit back to 80% when it detects that you're charging at home again.
