ChargePoint 3.3 kW Charger Question
Discussion in 'Model 3: Battery & Charging' started by Tocunvt, Aug 14, 2018.
  1. Tocunvt
    Tocunvt Member
    Washington D.C.
    Anyone have any experience charging a Model 3 at the subject line? There’s 2 of these next door to my buiding and I’m curious about the mph charge rate (Google results are all over the map).
    If anyone’s curious - the charge is $1/hr for the first 3 hours, then $2.75/hr after that.
  2. Kirby64
    Kirby64 Member
    Austin, TX
    3.3kW is equivalent to ~220V 15A, so a 6-20 (220V, 16A). Shouldn't be much different. So, roughly 15mi/hr charging. Insanely overpriced unless you're desperate for a charge.
  3. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Are you sure it’s onky 3.3kW? That would only be about 15A at 208V. If so, you’ll get about 12 miles/hr. Not worth it, especially after 3 hours, unless you can’t charge at home.
  4. TexasEV
    Austin, TX
    But it’s not going to be 220V at a commercial location. It will be 208V service, and more realistically closer to 200V. So even worse than you think.
  5. Tocunvt
    Tocunvt Member
    Washington D.C.
    Yeah I thought it was low too, especially for a brand new station...but that’s what it says on PlugShare (3.3).
    And I don’t have one at home...yet. Still fighting the HOA battle.
  6. TexasEV
    Austin, TX
    I see the CT4000 which usually has 30A output comes in a 16A output version also, for 20A circuits.
    ChargePoint— We’re overpriced, but we’re underpowered.
    • Funny x 2
  7. tjkessler
    tjkessler Member
    Campbell CA
    We have chargepoints at work all connected to commercial 208V service. The single chargers deliver a pretty reliable 3.3kW, however, when you plug 2 vehicles into a dual charger I've seen the charge rate drop to as low as 2kW.
  8. Tocunvt
    Tocunvt Member
    Washington D.C.
    So would you agree with the (roughly) 10 mph charge rate?
  9. tjkessler
    tjkessler Member
    Campbell CA
    That sounds about right.
  10. ronin
    ronin Member
    Is that roughly equal to $0.30 per kWh?
    The one at my work is $0.14 per hour and its a 6.6kW station. I'm assuming that's pretty cheap?
  11. tjkessler
    tjkessler Member
    Campbell CA
    $0.14 is pretty typical. Commercial power rates vary from $.08 to $.15 in most places. My employer
    picked the average price we pay over a day $.10 and then chargepoint adds $.01 for maintenance and
    billing. At home I pay PG&E's exorbitant $.34. So I don't charge at home unless I really need to do that. I need to get solar soon.
  12. Kirby64
    Kirby64 Member
    Austin, TX
    Yup, assuming you actually get the full 3.3kW that's approx. $0.30/kWh for the first three hours. That rate jumps to $0.83/kWh after 3 hours. Ouch!
    If you actually only have to pay $0.14/hr for a full 6.6kW, that's probably a lot cheaper than charging at home. You're paying effectively $0.021/kWh. Pretty good if you ask me.
  13. ronin
    ronin Member
    Yeah, I was shocked to see this at my work. Guess I know where I'll be charging mostly. :)
