I have a ChargePoint CHaDeMo/Combo DC Fast Charger at work which is supposed to charge at 50 kwh. I use it with ChaDeMo adapter my charge rate is 40 kwh. Does any know if it is the car's limit or CHaDeMo limit?
Faster charging at higher SOC is absolutely true when the charger is amperage-limited like it can be with today's existing CHAdeMO/CCS chargers with cars with big packs that are capable of pulling higher power like a Tesla using a CHAdeMO adapter.That implies faster charging at higher soc. that would be untrue.
To answer the op, your car can take 50kw,
I generally start with 50%, but it has nothing to do with the starting point. it starts with 40kwh and stays at that level until it gets to 85% and then goes down.How empty was your battery when you started?
It is true that CPE200 has a maximum 125A but it is @ 400-500V. Next time I am charging I will check if the voltage or the amper is limited.The "50 kW" rating is misleading because the actual power is dependent upon the design of the car's battery pack and the cell configuration within it.
For example, the S90 battery cell configuration results in a higher pack voltage than the S60 configuration when both packs are at the same state of charge (like 50% or whatever). Higher states of charge also result in higher pack voltage so the pack voltage rises gradually while charging.
The "50 kWh" charger is really limited to 125A so at a pack charging voltage of 320 that will give 320V x 125A or 40,000 Watts.
An S90 charging at the same ChargePoint 50 kWh charger at the same state of charge will charge at a higher power at 125A than an S60 at 125A.
This 40kW happened to me when I tested my Chademo adapter for the first time (I have a ChargePoint CHaDeMo/Combo DC Fast Charger at work which is supposed to charge at 50 kwh. I use it with ChaDeMo adapter my charge rate is 40 kwh. Does any know if it is the car's limit or CHaDeMo limit?
