Charger Door--forget to close
Discussion in 'Model S: Battery & Charging' started by efusco, Dec 5, 2012.
  1. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    Perhaps this will become a bit more natural, but I've, so far, forgotten to close the charge port access door as often as I've remembered to close it. Too bad there's not a remote closing option too. I'm usually just impatient to get going as soon as I get unplugged.
  2. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    I did this once or twice. Now I just taught myself to close it as soon as I pull out the plug.
  3. vfx
    vfx Well-Known Member
    CA CA
    It's on your screen that it's open but it's too small. Dr Computer said that car should beep and/or have a much large warning on the cluster where other warnings appear..
  4. Liz G
    Liz G P03056
    Wentzville, MO
    Along that line, does the car prevent you from driving off with the UMC still plugged in?
  5. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    It does but you can drive with the charge port open.
  6. vfx
    CA CA
    Only gasoline cars let you do that.
    car gas hose.jpg fail-owned-gas-nozzle-fail.jpg what-was-the-driver-thinking.png
  7. Zextraterrestrial
    Humboldt/Los Altos
    I love that the cars w/ hoses in the pictures have made it off the station property and driving! very observant drivers :scared: glad I can stop on a dime for them!
  8. Arnold Panz
    Arnold Panz Model Sig 304, VIN 542
    Miami, Florida
    Evan, you also have to hold it for a second or two until it "clicks" in, because I've had a couple of occasions where I've closed the charge port door only to have it pop back open because the magnet doesn't latch on for whatever reason.
    My biggest issue is not shutting my garage door when I drive off after unplugging the car. Gotta get used to doing that. Maybe the "green" homelink will help with that once I get the software upgrade.
  9. Sparrow
    Sparrow S105/ Roadster 189
    Marietta, GA
    I've never had to hold my charge door closed. It stays shut even before the click signaling that it is locked.
  10. Arnold Panz
    Miami, Florida
    Mine always closes, but popped back open a few times when it "clicked", so learned to just hold it there for two seconds until it "clicked", and then I don't have any issue.
  11. derekt75
    derekt75 Member
    San Jose, CA
  12. kendallpb
    kendallpb Model S: P 8061
    MD, USA
    Remote closing: Another good idea, Evan. I suspect this would take hardware changes, though, so I don't expect it to happen in this version (if ever).
    I like threads like this; it gives me ideas of what things to watch out for and things to get used to doing.
  13. efusco
    I did it again tonight...oye.
  14. widodh
    widodh Model S 85 and 100D
    Venlo, NL
    Couldn't they just make the warning bigger or refuse to go into 'D'?
    That would solve it all, right? On the other hand, just close it! ;-)
  15. efusco
    I don't know if I want it to prevent "D", but an audible and more obvious alert would help.
  16. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    I solved this problem with my roadster - a big sticker on the HPC ('Did you close the charge port door?') near where I hang the charge cable.
  17. Trnsl8r
    Trnsl8r S85 2012-2018, X90 since 2016, 3 since 2018
    San Jose, CA
    Yeah. I wouldn't want to get stranded just because the charge door is busted or broken off or something.
  18. NigelM
    NigelM Recovering Member
    Northern Virginia
    [video=vimeo;5371237]http://vimeo.com/5371237[/video]
  19. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
  20. EchoDelta
    EchoDelta Supporting Member
    Seattle, Planet Earth
    It happens to me all the time with my current PHEV. Especially in chargers outside where one uses both hands to reel in the heavier charge cables and then you walk on the wrong side of the car and then you see the dashboard alert and the little open flap in the rear view mirror .. DOH.
    I definitely would recommend a remote close for future tesla revs. eg maybe make the door drop inwards and slide out of the way.
    - - - Updated - - -
    Made me think of EVs with magsafe. Fortunately they dont go into D while plugged in.
