Charger Etiquette: OK to Unplug Once Complete?
Discussion in 'Model S' started by mike-415, Jul 21, 2017.
Tags:
Is it OK to unplug an EV from a charger when it's done?
  1. Unplug it!
    23 vote(s)
    82.1%
  2. No, that's rude!
    5 vote(s)
    17.9%
  1. mike-415
    mike-415 Member
    Greenbrae, CA
    I was leaving from SFO on Tue and needed a charge and the only open spot had a charger that was plugged into a different Model S in the adjacent spot (multiple spots share one charger at SFO). The charger display said "Power reduced, charging complete or paused", so the Tesla was done. OK to unplug the charger and use it?
  2. kev1n
    kev1n Member
    Bay Area
    I thought you cannot unplug a Tesla if the car is locked?
  3. mike-415
    mike-415 Member
    Greenbrae, CA
    You can't unplug a Tesla charger. You can unplug a public EV charger from the Tesla adapter. SFO has standard EV chargers, not special Tesla chargers.
    • Informative x 2
  4. croman
    croman Active Member
    Chicago, IL
    If its done charging, why not? J1772 adapter will stay locked in the other car. You might want to leave a note.
  5. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Normally I would say not to unplug, but an airport is a different situation. The economy lot at LAX has a large bank of level 2 charger with really, really long cords. That allows people to swap out plugs as needed over about three parking spot lengths so it's easier to share. When I left I was plugged into one unit and when I came back someone had swapped me over to another charger, which I appreciated.
    Now, if there is signage that you must be plugged in, then unplugging someone else risks giving them a ticket, so I would not unplug in that situation.
  6. kort677
    kort677 Banned
    florida.
    if the car is not using a adaptor you will not be able to unplug it
  7. JPUConn
    JPUConn Active Member
    CT
    Absolutely ok in this case.
    At my work there is a single level 2 charger and a Chevy Volt uses it as his personal parking space. I go down at lunch and confirm from the volts dash light and the charger status that he's done charging and unplug to plug my car in when I need the charge. The volts alarm beeps for a few seconds after you unplug it unfortunately.
  8. kort677
    kort677 Banned
    florida.
    would it be hard to enlighten the volt owner that the space is a charging space and not a parking space?
    recently I was at a restaurant in CA that had 2 destination chargers. one was iced by a pick up and one had a tesla parked nose in and was using as a parking space. after I thanked the manager for having the units installed I learned that both cars were owned by employees, I alerted him to the fact that the chargers are useless if blocked like that his response was to come inside and they'd move one of the cars, apparently they had an ICING issue and this was their method of solving the problem.
