Charger Issues During Extreme Cold Weather
Discussion in 'Model S: Battery & Charging' started by iKhalid, Jan 14, 2015.
  1. iKhalid
    iKhalid Member
    Ottawa, ON
    Hello everyone!
    I know this was mentioned in the other thread by our Norwegian friends, but my post is very specific to the chargers used, which might be the source of the issue.
    My case might not be very unique but it is unique enough to narrow down the source of the issue.
    I live in Ottawa (Canada) and the temperature right now is extremely cold (-26˚C/-15˚F). I park outdoor since I don't have a garage and I have a small L2 ClipperCreek LCS-20 charger at a curb post.
    Last month, I was away for 3 weeks and I noticed that the charging has stopped and cannot be initiated 3 days before I came back. I called Tesla when I was away but there was nothing that could be done remotely. When I came back I noticed that the charging kept disconnecting when the cable is touched. (issue#1) It was so sensitive so I switched to my UMC and it was charging fine. However, monitoring the charging status overnight using the app shows me that the current keeps dropping a few times per hour. (issue#2) I called Tesla and they sent a ranger with a loaner and they took my car. It turned out it was an issue with the J1772 adapter, which they replaced and brought my car back. (issue#1: solved)
    The car was charging fine at the SC (indoor) so I thought it could be an issue with my L2 charger. But again, I still experienced the issues with the UMC but I thought it could be a one time thing at the time, so I ignored it.
    It's been two weeks now and I can tell you no matter what I use to charge my car, the current keeps dropping and the charging stops a few times per hour when the temperature is below -20˚C. I read somewhere that ClipperCreek is the current maker and supplier of Tesla chargers (I don't recall the source but correct me if I'm wrong, it could be ClipperCreek's video) so it could be that the operating temperature of their equipments is stated wrong. From their website: "Operating Temperatures: -22°F to 122°F (-30°C to +50°C)".
    The only reason I'm blaming the charger for now is because
    Norwegian owners don't have the same issue using other chargers or other electric cars. If someone in Canada or Norway could confirm that they don't have issues using L2 chargers that are not made by ClippersCreek, that would be helpful to us and to Tesla Motors.
  2. andyro
    andyro Member
    Toronto
    #2 andyro, Jan 14, 2015
    Hi iKhalid, I have had numerous problems with cold weather charging, and have had an electrical engineer, plus several master electricians and Tesla engineers look at the situation, and finally a solution. I also park the car (90% of the time outside) - as my garage is essentially my dining room and a messy car is usually unwelcome there! There are many possible causes. First and foremost is that I find even the tiniest film of ice or condensate on the inside of the charge port or adapters can cause problems, especially after a wash in colder temperatures. Tesla, after all of their investigations, had noted that voltage fluctuations caused drops in amperage allowed, and if these continued, outright stoppage of charging. This was experienced repeatedly with both my UMC & 40amp outlet, and at a few SC CS90 outlets (outdoor). This happened more frequently in colder weather. The master electrician hired by Tesla concluded after substantial testing (they were here all day, switching on and off loads, maxxing out my system on a 200amp panel) - two findings; a) that my pole-mounted transformer was too far away from my panel (by a good 150' or so), and b) that the guage of my underground service wire was too light for the run of just over 400' from the transformer. I heard their argument, but was still skeptical. None of my computers, boiler, induction stove had a problem with these 'voltage fluctuations' - so why was the car being so fussy? The car itself was subsequently inspected on a few occasions, and no faults were found - 6 months later my precharge system went on permanent strike and bricked my battery, which has been replaced after flatbedding to MTL, but presumably this is unrelated ;)
    I asked Tesla whether a HPWC or CS90 may be installed - just as something different to try, but all parties insisted that the HPWC would make no difference and amperage would step down no matter what. Still skeptical, I purchased a HPWC and had it installed. I mounted it a good 5' away from my panel in the case that some back-induction from my boiler or panel may have been causing an issue. Now despite all gospel truths about the quality of my infrastructure, the car charges at 80amps (92km/hr) consistently, and steps down only to 69amps on the rare occasions that my 100amp boiler, stove, and charger are all in use at the same time. The nice thing about the HPWC is that it is smart enough to reset to 80amps when it can, and/or it allows the interface on the car's console to be dialed up to 80amps again, whereas with the UMC it would lock into 30amps, and cite 'bad wiring or extension cord used' warnings. Apparently I had a ground fault issue at my panel at one point also - but I really think that this all has to do with an over-sensitivity of the software to take offence when my voltage drops from 254 on plugging in, to a low of 233 in some cases. In any case, the HPWC has been a huge improvement, and one that is not really endorsed or understood by Tesla, IMHO. The speed or recharge with the HPWC has also been extremely welcome - I can plan back-to-back trips with less downtime, and precharge (battery and cabin warming for max. regen & console boot time reduction) before a trip now takes minutes where it used to take even an hour or more.
    The explanation (offered to me by Tesla's electrician) for the larger fluctuations in Voltage during the colder weather, is that the overhead lines physically contract/tense up, and this causes a difference in the voltage. I scratch my head. It would therefore seem that a stretched/hot wire would be subject to a greater drop as the cross-sectional area may be reduced. Either way - it sounds like a bit of voodoo. My recommendation would be to see if you can borrow a HPWC from Tesla to see if it fixes your problem, and make sure you blow-out all moisture with a hair dryer before you take a longer trip. Does that help? A question for you - do you find your charge port door sticky in cold weather - as in needing an occasional pry open - or failure to magnetically latch sometimes?
  3. iKhalid
    iKhalid Member
    Ottawa, ON
    Thanks a lot, andyro!
    What an experience you had! Unfortunately, I can't borrow an HPWC because I can't install it anywhere here. I would've bought it if I had a garage. $750 is not expensive at all. I already paid (with taxes) more than $500 for my 15AMP charger, which is basic and slow!
    However, we always have Tesla's HPWC at their new SC in Montreal. We can test that!
    Just for the purpose of scraping my theory, who makes the HPWC and who makes the UMC?
  4. tga
    tga Supporting Member
    New Hampshire
    I think you're confusing the Roadster's HPC and the Model S HPWC. The Roadster HPC (aka "TS-90") was a rebadged Clipper Creek CS-90.
  5. Matias
    Matias Active Member
    Finland
    I've understood Norway has special electric system and it has maybe contributed to problems. How often this happens in Canada? If I buy Tesla, I have to charge it outdoors and weather will also sometimes be -20 C or colder here.
  6. Kalud
    Kalud Active Member
    Montreal, QC
    I haven't opened my UMC but I remember that one posted pictures of the internal in these forums, but in the other hand the HPWC has all TESLA internal electronic circuits, I'm pretty sure they are made in-house or designed in-house and then built elsewhere.
  7. hydro
    hydro Member
    Québec
    Hi! Sorry to see you're having issues. We've had our dual charger S85 for just about a year (dec 2013) and the car is outdoors all year. We're at 58000 km so far and have an HPWC @ 80 amps. This morning, while answering a post on Tesla Motors' forum about charging during cold snaps, I realized that our HPWC is the northernest one in Canada east of Winnipeg. Other than having the HPWC's cable change during the summer due to the known button problem (corrected since then), our HPWC is doing great outside. In my opinion dual chargers and HPWC should be standard in Canada as we have a lot of high amp outlets thanks to Sun Country's network as well as EV owners that understand the importance sharing at this stage of the game. Also the electricien that did our install mentionned that the nearest pole transformer might be a bit far so we called Hydro Québec and they did install one on the pole in front of our house. Great service by all involved : Hydro, Tesla and my electricien. We are very happy Tesla owners. Good luck. I'm certain you will find a solution.
  8. iKhalid
    iKhalid Member
    Ottawa, ON
    Yes, it could be the one made for the roadster.
    - - - Updated - - -
    Thanks for the info!
    - - - Updated - - -
    You're the second person to state that the HPWC doesn't have issues when it's cold. Can we say that the high current makes the charger and the cable hot enough that it makes up for the extreme cold temperature?
  9. andyro
    andyro Member
    Toronto
    My HPWC is outside also, and I agree, it should be standard in northern climates. The UMC was a big waste of time for me...
