I don't have my Tesla yet, but I am trying to plan the installation of a Tesla wall connector.
The diagram above shows the possible locations I am considering, but I am not sure what is best. It is a two car garage, and the Tesla will be the only car parked there.
Location 1 - This is closest to the electrical panel, so it would be optimal in terms of electrical wiring and cost. It should work no matter which orientation the car is parked, as long as it is on the right. The only thing I don't like about it is that the charger and the door to enter the house are in opposite corners of the garage. This might be a stupid thing to worry about. I am just thinking that I will be using this setup for years and getting in/out of the car thousands of times.
Location 2 - This would be closest to the charging port if I park nose in, which is the way I am used to parking. My concern here is that the charger would be on the opposite side of the electrical panel. Is it reasonable to install that way, or is it not recommended if you have other options?
Location 3 - This would be closest to the charging port if I back in. I will still need to move between opposite corners of the garage when getting in/out, and it is not the closest to the electrical panel. I think this is the worst option.
