Charging Adapter very Hot warning
Discussion in 'Model S: Battery & Charging' started by Mucall, Sep 28, 2017.
  1. Mucall
    Mucall Member
    Fayetteville NC
    246B6C36-E094-449D-8267-B5E3DB873E9F.jpeg Has anyone had this issue before.? My first time after a year+ ownership and lots of long distance trips.
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I'd recommend trying some contact cleaner on both sides. Probably making a poor connection, which increases resistance and therefore heating.
  3. Mucall
    Mucall Member
    Fayetteville NC
    Thanks. I’ll give it a try. By the way this was using the Chademo adapter
  4. Doug_G
    Ottawa, Canada
    If it happens again, feel it to determine if it's the car plug, the Chademo plug, or the adapter box thing that is hot.
  5. Mucall
    Mucall Member
    Fayetteville NC
    The handle was the hottest, charge door area was normal, the big black piece and the actual chademo hose were not hot at all. Next charge I will check those again. Thanks again
  6. Cosmacelf
    Cosmacelf Active Member
    San Diego
    Yeah, never seen that before. Do you have a relatively recent Chademo adapter? Obviously there is a temperature sensor in it somewhere...
  7. Mucall
    Mucall Member
    Fayetteville NC
    I bough it a year ago
  8. David99
    David99 Active Member
    Brea, Orange County
    Yes I have seen this with the CHADeMO adapter. It was on a very hot day and the sun was shining directly on the adapter. My adapter is one of the very first ones. They always had a temperature sensor built in.
  9. Mucall
    Mucall Member
    Fayetteville NC
    Fantastic. Thanks for sharing the info.
