Thank you all for your answers. So, I can use a 40A breaker on the two 14-50 outlets I will be adding. I will be clearly labeling each outlet as to what power they offer. The large panel has a 125A service disconnect breaker (the panel's main breaker).
If for example, I had all four of the 14-50 outlets I am planning for, being used by: two Tesla's and two Leaf EVs, all should be OK as the Leaf EV only has a half-powered (3kW) on-board charger. It would be like using the same power as if I there were only three Tesla's drawing 6kW each (well within the spec of the 125A panel with all other breakers off).
Because there was so many post-2010 Production EVs at the eaasv.org EVent is why I am making the effort to make the large panel more usable. It was originally built for the needs of the late 1990's. Clearly there are far fewer level1 needs than level2, and they will be for 6kW level2 power.
That was made quite clear, as you said, as there were many Tesla Roadsters at the EVent. First thing in the morning I saw them in come in one right after the other. Wow, that was about $1M worth of EVs right there! Each of the public I talked to that day I made sure they knew that the Tesla drivers were very generous in coming and letting the public put their dirty feet in their sweet ride. My thanks to you all.
I was aware at the end of the EVent that the large panel did have a grounding issue. A Leaf EV that was using one of their modified level1+ rev2 EVSE (a level 1 EVSE changed to provide either level1 or a 3kW level2), also had a fault as well. The Chapter's electrician said the panel was not hooked up right (he did the work so he would know). I am hoping that with due diligence to remind the electrician of this will ensure a proper hookup of the HS' 208VAC power, thus we will not have that issue again.
The chapter has two panels, a large 125A panel (the one I am working one), and small panel. It was that smaller panel that TEG used to get a charge. Some history: both of those panels had charged the original first run older-Production EVs in the late 1990's (EV1, RAV4-EV, Honda+, Think, etc.) when that Chapter's EVent was held at Stanford University.
By my adding of two more 14-50 outlets to the large panel, will let it have a longer use/life.
Thanks again,
-Bruce
