New member so trying to jump in. I am currently looking at buying a MS and I have a question about charging set up at my home.
My current home circuit breaker has a door sticker stating max is 125 amps and I have the main breaker (2 breakers together with plastic showing 100 on each) that from what I can gather is 200 amps. So I’m unsure if breaker is 125 or 200.
Question is: can a 125 amp circuit breaker handle a NEMA 15-40 addition? I would have an electrician do the work (I am sure by the question you can tell not electrically inclined).
I have read that the actual circuit breaker it uses is a 50 amp.
Thank you in advance of you answers!
I look forward to learning about the MS here on these forums.
