It looks like you have an electric hot water heater and air conditioning as your major loads. I believe your dryer is gas, as there isn’t a 240 volt breaker for it.
Between the two major electric appliances, you’re at 40 amps load. Between your other items like the furnace blower, general lighting, smaller appliances like an iron, fridge, dishwasher and a couple of computers, you’re at another 15-20 amps of load (calculated at 240 volts). Given that you’re only breakered at 100 amps, with would be 80 amps of continuous load, I don’t think you’d be wise to put in much larger than a 30 amp breaker for the car. That 30 amp breaker should allow you to charge at 24 amps without having to worry about what other appliances are running.
If your panel and the wiring that feeds it are all rated for 125 amps, you might be able to upgrade your main disconnect to 125 amps instead of the existing 100 amps. That would give you a litle more head room for a larger car charging circuit.
Your power company might be able to provide you with a detailed energy usage report. With that information, an electrician can give you an educated opinion on how to proceed.
