I have used the
Quick 220 Systems: Voltage Converters and they just throw away the neutral and use two line/hot sides and ground for the output.
Quick 220 Systems: 20 Ampere Straight Blade Outlet is the one I have and it has a 6-20 output, which seems very reasonable. The big problem with these boxes is caused by how they work. All of the current passes through the two line/hot wires, and nothing is returned to either neutral (not connected). Because 120V GFCI's detect possible ground faults by sensing current differences between line and neutral (the assumption is that any difference is a ground fault), GFCI circuits immediately pop/fault, and you get nothing. In modern construction, all outside, garage, bathroom, and kitchen outlets are on GFCI's, so it's really hard to find a pair of outlets on different phases that will give you current. When I got it to work, it meant hauling extension cords into front hallways, etc.
