Charging car battery on the move with wind power
Discussion in 'Technical' started by Retellect, Nov 26, 2009.
  1. Retellect
    Retellect New Member
    UK
    My son came to me today with one of the strangest and creative concepts on how to help charge an electric car with wind power to make it more efficient. He suggested that one could cut out "scoops" in the cars body that would aerodynamically channel air down a tunnel. Using a method similar to what dyson used in their bladeless fan called the Air Multiplier, you could amplify that airflow to spin an internal motor generator.
    The way he explained it to me, it would only be passive. That means the aerodynamics would assist cars efficiency and drive a highly efficient motor generator without causing drag. What are your opinions on this idea? Do you think its worth looking into?
  2. Tdave
    Tdave Member
    Owings Mills, MD
    1) There's no free energy.
    2) It will indeed cause increased drag.
    3) You will generate a fraction of the energy lost to the increased drag. (See #1).
  3. stopcrazypp
    stopcrazypp Well-Known Member
    As Tdave says, there is no free energy.
    One place where you can conceivably get some useful energy is to use this as an air brake (like the spoiler on the SLR). But it seems like a very complicated system for not much gain.
  4. Mark Petersen
    Mark Petersen Model S EU P71
    Hørsholm, Denmark
    ther is only one way we can use wind energy and that is if we are able to catch side or tail wind, but that is going to be to little to utilice
  5. tdelta1000
    tdelta1000 Active Member
    South Florida
    Hey Mark,
    A fan or several smaller fans can be placed up front to catch the some wind possible. just think about radiator fan or an ac condensor fan.
  6. edo
    edo Member
    There was a such thing as sail cars. I don't know if this would be more effective or not, but i'm guessing it might work in a stiff enough wind. No wind, no dice.
    Here's a thought experiment:
    A 30 mph (50kph) headwind should produce enough energy to allow someone to travel 2-3 mph. and traveling 33 mph should be a marginal increase in drag.
  7. windgrins
    windgrins Member
    Atlanta, GA
    Mark, surprisingly there is a complicated way to use any wind over the ground--tailwind, headwind, whatever. There is no way to gain anything if the wind isn't blowing over the ground, though.
    See this blog as to how a car with no motor whatsoever and no stored energy did it with both a tailwind and a headwind. It's fascinating and counter intuitive.
    A Long, Strange Trip Downwind Faster Than the Wind
    and
  8. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    It's on an airport, but I'll bet it'll never take off!
