Charging continuously cycles on/off
Atebit
286
26
PA
So I just upgraded to v7 this past Friday. i just moved into a new house where I don't have a TOU program on my electrical service yet, so I don't have a charge timer set. As usual I keep the car plugged in to my HPWC.
This morning (Monday) I noticed that my phone was showing a bunch of charging started/stopped messages, all within 1-5 minutes of each other. I went into the mobile app & hit the stop charge button and this seems to have broken the cycle for now.
I checked the charge cable & it's securely connected to the car. The fact that I was able to break the cycle via the app seems to me to exonerate the HPWC. It's almost like the car stopped applying hysteresis to the charge level and wants to charge as soon as the charge level is lower than what's set. Anyone else seen this?
FlasherZ
Sig Model S + Sig Model X + Model 3 Resv
Jun 21, 2012
7,024
1,013
I can't say that I have. I doubt it would be the HPWC or incoming power - typically, that will result in a red ring after a few tries, and you'd need to unplug and replug to make it recover.
BertL
2,018
1,573
Carlsbad, CA
Agree it's odd what you're encountering. I keep my MS plugged into my 80-amp HPWC nearly all the time it's in my garage. I have the MS set to charge beginning 12M every day (when my lowest TOU rate goes into effect). Only once have I encountered a situation with the Tesla App reported charging was interrupted right after 12M, but when I checked the car the next morning, a full 90% charge had been completed after that -- and yes, I was running 7.0 when that occurred, but I've had no such thing occur several weeks since.
I don't know if it would make a difference, but if I were you, I'd at least reboot the 17"... I had funny things occurring immediately after 7.0 installed and a manual reboot solved it. I'm learning with my MS that a reboot from time-to-time solves unusual problems, just as it always did for years with my former Windows-based PCs before I moved to a Mac. ;)
AudubonB
One can NOT induce accuracy with precision!
Mar 24, 2013
7,976
25,904
I have had a similar situation recur quite a number of times in the past several weeks: my notifications say "charging started 0700" then "charging stopped 0700" then "started 0700" and it takes. Awaiting an answer from Service Center who is pulling full logs.
Atebit
286
26
PA
Thanks for the replies. HPWC is as new as the house :) so I would hope to not the handle going bad, but it's always possible. I'll see if I can find the threads on cleaning the charge cable contacts. AudubonB please let me know if service finds anything in the car's logs.
In in my case the car was pretty much fully charged to my set limit already, then after depleting let then a mile of range it started the dance. Since stopping it via the mobile app this morning it's been well behaved...
Andyw2100
6,542
2,393
Ithaca, NY
Let me guess: android app?
I ask because the first night the new android app was capable of notifications, my app showed the charging interrupted notifications. I had Visible Tesla running as well, and it showed no signs of the charging having been interrupted.
This has continued, with the android app indicating issues, and Visible Tesla not showing any problems.
I am reasonably certain the problem lies in the android app, and not in the hardware.
