Charging Errors
Anyone have a fix for the following error I'm getting on my screen:
Charging Disabled - Close Charge Port Door and Try Again Never Insert Charge Cable Using the Charge Port Lever - Using Lever to Insert Cable Will Prevent Charging
I've done a screen reboot and powered off the car with no luck clearing the error.
Let me know my Tesla Model 3 friends.
I just got the same error on my S, turned out to be an issue with one of the wiring harnesses, required much service.
Whole canbus system was failing though. Not likely your issue, hope you figure it out soon.
