charging etiquette - someone disconnected me
hemants
117
5
toronto
Was parked at ACC under longos for a couple hours. Someone disconnected sun country charger and left my adapter hanging out.
My charge was full so no harm was done.
Kosher or not?
hemants
117
5
toronto
Kosher or not?
LJordan
42
38
Bolingbrook, IL
If no other chargers were available at the site, Kosher. I assume they could tell you were full. I would leave you a courtesy note and explain why I unplugged you.
Az_Rael
5,654
8,944
Palmdale, CA
I would say neither action was good etiquette. You should have returned and moved your car when charging was done to free the space, and the other person probably shouldn't have unplugged you. (I am not a fan of strangers messing with other strangers cars even if they aren't charging)
But do remember that charging spots are not parking spots for your future endeavors. You had basically ICE'd out that other EV.
TexasEV
7,650
8,911
Austin, TX
I've seen CHAdeMO stations that display the car's SOC on the screen, but can some J1772s do this? Otherwise how would the person have known your Tesla was fully charged?
Az_Rael
5,654
8,944
Palmdale, CA
Most Level 2 chargers show if the vehicle is charging on the main unit in some form, either via colored lights or a screen.
Phillip L
Gas Passer
Mar 31, 2015
729
594
Owen Sound, Ontario, Canada
Think about it from the perspective of the other person. They need a charge, maybe REALLY need a charge, and there is a charger not being used. I see no problem with them using the charger. They are not really messing with your car, just removing the charger cord, which is not even directly connected to your car, since it is the adaptor that is. That being said a note would be nice.... but tell me, how many people carry around a pen and paper to leave a note?
bonnie
I play a nice person on twitter.
Feb 6, 2011
16,429
9,931
Columbia River Gorge
I always leave my cell number, in case someone needs to charge (whether I'm still charging or not). That's probably the best 'etiquette'. That way if I don't get back right when my charge is done, they can still call me and ask if it's okay.
I used to use just a note, now I've graduated to using one of these hangtags, leave it hanging right on the car charge port:
wallstguy
556
463
Toronto, Canada
And they knew the car was full how?
Not 100% on this as I'm still waiting for mine to arrive, but I believe the rep told me its displayed on the big screen which should be easy to see?
Maybe it's the charger changes colour like the other poster mentioned (not sure if this happens)
Az_Rael
5,654
8,944
Palmdale, CA
Not sure what particular kind of sun country charger you were at, but this one has a light for charging, for example. If that wasn't on, they would have assumed you weren't charging.
cgiGuy
1,503
1,119
Everywhere, Nowhere
Many times a single charger is set up for 2 parking spaces for this very reason. We're a community and as long as there's a way of knowing if you're done charging, it should be ok to unplug if they need the juice.
Not if Tesla would keep the charge port light active, this would be much easier...
Reactions: Galve2000
TexasEV
7,650
8,911
Austin, TX
Yes it displays on the screen and the charge port lights up, BUT ONLY IF YOU HAVE THE KEY FOB PRESENT. A stranger would see neither.
Reactions: SW2Fiddler
