Charging Habits
sleepies
24
3
Orange County, California
After reading many columns and threads, I’m still a bit confused on the best way to charge my Model Y.
My daily commute to work is 2 miles each way. I currently rent a room in a townhome with no home charging but my workplace provides free charging. Every Friday after work, I drive 130 miles back home where I do have a home charger installed in the garage of my primary residence. Then on Monday or Tuesday morning (depends on when I flex - 9/80 schedule), I drive 130 miles back to work and charge at work to 90%. Then rinse and repeat.
(1) Should I charge each weekday to 90% at work and then stop to free up a spot for another car to charge.
(2) Keep it plugged in all day until I’m off (this will make me hog a spot and prevent others from charging).
(3) Charge when I get back to work from the weekend to 90% then don’t charge the rest of the week until Friday before I head home for the weekend?
(4) Or any other recommendations?
Sorry, I have a headache myself just thinking about all these possibilities.
DonaldBecker
118
115
95033
It doesn't matter that much.
Keeping the state of charge between 50-80% is very slightly better than 30-90%.
I suggest charging to 80-90% at the beginning of the week, and only topping up if you drop below 50%. Then charge to 90% just before the trip home.
It is better to charge to 95% or 100% indicated than drop below 20%.
Reactions: sleepies
Oct 3, 2020
140
160
Seattle
If you want to make to most out of the free charging at work, I suggest charging to 100% on Friday, while ensuring that you leave work shortly after it finishes. When you get home, only give it enough charge to get back to work on Monday, which may be nothing at all depending on how efficient your driving habits are. When you get back to work, your SoC should be low, 10-20%.
At this point, I suggest maintaining a charge between 50-70%, especially since it’s such a short trip. If you’re not using sentry mode, you could probably get away with charging to 70% on Monday and not have to worry about topping up until Friday.
This approach will certainly have an impact on your electric bill.
Reactions: sleepies
Big Earl
bnkwupt
Jul 12, 2017
4,915
8,790
Springfield, VA
Charging every day seems silly when you’re only consuming <10 miles of rated range. It’s also inconvenient to move the car every day after less than 30 minutes on the charger, which segues into scenario two, which is very poor charging etiquette.
Scenario three will lower your average state of charge for the week. I personally like to keep the car more than half full in the event I need to drive a long distance unexpectedly.
My recommendation is to charge at work twice per week. Once before your trip and once on your first day back. That has you using the communal chargers only twice per week, vacating the charging station at lunch and keeping your average range up in case of an unexpected travel event. If you end up consuming more range than expected due to extensive preheating or additional weekday driving, add a third charging session to your work routine.
