Either get the wall charger, expensive, or have a NEMA 1450 outlet installed, less. You need to buy the adapter for your UMC to plug it in. 35 bucks in the Tesla store. In either case you’ll have to run 6 AWG wire from your panel to where you want to charge and a 50 or 60 amp breaker. Congratulations on your new car. Enjoy.Ordered 2021 MS 2 weeks ago and I'd like to know what to expect for getting the car charging @ home such as wall plug, connector etc...
The problem is my breaker box and the garage are not on the same side so that will be tough to doMaybe u r a geek? Depending on where your breaker box is in your house, and where u park? U can install the 14.50 receptacle yourself. Took me an hour. Go to HD, buy the double 50amp breaker, 14.50 box with receptacle, wire have a fun time. It's not rocket science. When u pull cover off breaker box u will see how simple it is. There a lot of videos on YouTube to assist u. Good luck.
14-50 on a 60amp circuit is wrong should be 50amp.What he said. I home setup is a 14-50 outlet on 60-amp circuit. Perfect.
The HD receptacle is NOT-rated for frequent plugins or 6-8 hours usage at maximum rated amperage. I learned this the hard way. The breaker isn’t either. Industrial grade parts rated for frequent plug inns and heavy duty service are $50-85 at electrical supply houses.Maybe u r a geek? Depending on where your breaker box is in your house, and where u park? U can install the 14.50 receptacle yourself. Took me an hour. Go to HD, buy the double 50amp breaker, 14.50 box with receptacle, wire have a fun time. It's not rocket science. When u pull cover off breaker box u will see how simple it is. There a lot of videos on YouTube to assist u. Good luck.
The wall charger will charge at 48 amps, the 14-50 outlet at 40. If you get the wall charger you should use a 60 amp breaker. The wire should be thnn awg 6 wire in conduit, not romex. If you get the 14-50 outlet then you can use romex as the charging rate is less.
