About the Battery
Model Y has one of the most sophisticated battery
systems in the world. The most important way to
preserve the Battery is to LEAVE YOUR VEHICLE
PLUGGED IN when you are not using it. This is
particularly important if you are not planning to drive
Model Y for several weeks. When plugged in, Model Y
wakes up when needed to automatically maintain a
charge level that maximizes the lifetime of the Battery.
NOTE: When left idle and unplugged, your vehicle
periodically uses energy from the Battery for system
tests and recharging the 12V battery when necessary.
There is no advantage to waiting until the Battery’s
level is low before charging. In fact, the Battery
performs best when charged regularly.
NOTE: If you allow the Battery to discharge to 0%,
other components may become damaged or require
replacement (for example, the 12V battery). In these
cases, you are responsible for repair and/or
transporting expenses. Discharge-related expenses are
not covered by the warranty or under the Roadside
Assistance policy.
The peak charging rate of the Battery may decrease
slightly after a large number of DC Fast Charging
sessions, such as those at Superchargers. To ensure
maximum driving range and Battery safety, the Battery
charge rate is decreased when the Battery is too cold,
when the Battery’s charge is nearly full, and when the
Battery conditions change with usage and age. These
changes in the condition of the Battery are driven by
battery physics and may increase the total
Supercharging duration by a few minutes over time.
Battery Care
Never allow the Battery to fully discharge. Even when
Model Y is not being driven, its Battery discharges very
slowly to power the onboard electronics. The Battery
can discharge at a rate of approximately 1% per day,
though the discharge rate may vary depending on
environmental factors (such as cold weather), vehicle
configuration, and your selected settings on the
touchscreen. Situations can arise in which you must
leave Model Y unplugged for an extended period of
time (for example, at an airport when traveling). In
these situations, keep the 1% in mind to ensure that you
leave the Battery with a sufficient charge level. For
example, over a two week period (14 days), the Battery
may discharge by approximately 14%.
Discharging the Battery to 0% may result in damage to
vehicle components. To protect against a complete
discharge, Model Y enters a low-power consumption
mode when the displayed charge level drops to
approximately 0%. In this mode, the Battery stops
supporting the onboard electronics and auxiliary 12V
battery. Once this low-power consumption mode is
active, immediately plug in Model Y to prevent a jump-
start and 12V battery replacement.
NOTE: If the vehicle is unresponsive and will not unlock,
open, or charge, then the 12V battery may have become
discharged. In this situation, contact Tesla.
