I've done this kind of thing many times. In fact, here is my reality (at your same scale factor) at my in-laws that I will be traveling to in a few weeks:
Their home is the purple marker...the cluster of charging stations to the north is in Canada, so not practical to get to! The cluster to the northeast is 45 minutes away. The marker just to the north is just a 120V wall outlet at a rental cabin. The nearest Supercharger is about 45 minutes to the south (en route to/from their home).
While I know that they have an easily accessible 120V outlet, I also know that their wiring is "problematic". My wife's Volt refused to charge at one of their outlets, probably because it was not a properly grounded outlet...but a different outlet did work. However, I didn't have a ton of faith in it (I limit the charging to 8A when I plug in there), and the first time I took the Tesla, I wasn't sure whether the UMC would have an issue with it or not.
For the first trip I took there, out of an abundance of caution, I charged to 50% SOC at that last Supercharger on the way there. I figured worst case that would easily get me back if I was unsuccessful charging from the 120V. Turns out there were no worries and I was able to fully charge the car before I left. Granted, it takes several days!
The next trip I set my arrival SOC target to 25% (just to be safe, plus we were planning on taking a side trip) and let abetterrouteplanner.com figure out how much I needed to charge at that last Supercharger. By the next trip I had more confidence in their outlet and I was probably aiming for a more typical 10% arrival SOC. It takes over 3 full days of charging at 8A to fully charge my Model 3 LR. (Of course my father-in-law just informed me they had some problem with that outlet and it needs to be rewired, so there goes my confidence!)
The net is, having a 120V outlet to charge from is key, whether at a hotel, cabin, or relative's house. At 8A charging speed, I get about 4 miles per hour of range. So for a 12 hour overnight stay, or 12 hour daytime visit, you can regain about 50 miles of range for your side excursions. Just make sure you have a good extension cord to use for this purpose. I have a 50' heavy duty 10 gauge extension cord. Do not use a standard household extension cord. You will melt it and/or get unacceptable voltage drop. And when you use an extension cord, avoid coiling it up on top of itself.
As for a practical recommendation, I would use abetterrouteplanner.com to experiment with various starting SOC in Bryson City for your return trip home. Find that magic starting SOC that will get you comfortably back to Asheville with 10% SOC and set that as your bare minimum target. Let's say that's 35% for example. This is the SOC you do NOT want to fall below at your remote end. Assume a certain amount of phantom drain at the remote end (make sure you disable Sentry Mode and maybe cabin overheat protection to reduce this, and try to avoid checking on the car and waking it up frequently)--maybe 5%. Then try to estimate how much you'll consume on your daily excursions. 25% more maybe? Add those up (35+5+25 = 65%) and this is the amount you will want to arrive at Bryson City with. Now flip ABRP and set a 65% arrival SOC at Bryson City and see how long you will have to charge at Asheville on the way there. Going through this exercise will give you a worst-case scenario that assumes no access to 120V outlets or charging, and you will know that what the bare minimum SOC will need to be before you leave Bryson City on the return trip. If you happen to find a 120V outlet, plug in give yourself some safety margin! If you know for a fact that you will have access to a reliable 120V outlet for part of your stay, even better...you can subtract about 1% SOC from your required Bryson City arrival SOC for each hour you will be able to be plugged in. I.e. if you know you'll have 24 hours of reliable charging time while there, you could technically arrive at Bryson City with 40% SOC rather than 65%.
I know that all sounds like a lot of work, but it's not. Hopefully you will be able to plug in most of the time you are there and you don't even have to worry about it and you can leave Bryson City with a full battery.
