Hello, I have been having an issue with my charging being interrupted or failing to start. Our garage has 2x 120V circuits, one outlet in each circuit is a GFI, and second is a normal outlet.
The issue is that the GFI oultet will open randomly overnight and i'll get a charging interrupted notification, this happens maybe a few times per month so it's not very frequent. A few months ago the standard mobile charger stopped working entirely and tesla replaced it for free, but this problem has persisted.
A couple weeks ago, I was unable to charge at all. As soon as I started charging, the GFI would open. I tried a second charger, tried the other circuit in the garage, same problem. I then tried both chargers and both circuits on my gfs model 3, which had no problems and was able to charge. So, it appears it's an issue with the car and not the chargers or the GFI outlets. Later that night I was able to charge again. I have a service appointment set up with tesla...
Has anyone else had this issue or know what the solution is?
