Charging issues after Firmware 6.0
Discussion in 'Model S: User Interface' started by drbradfo, Sep 23, 2014.
  1. drbradfo
    drbradfo Member
    Portland, OR
    Has anyone had charging issues after upgrading to Firmware 6.0 ? I upgraded on Sunday, and Monday morning noticed my car hadn't charged overnight, no worries, since I had plenty of range for the day. After returning home Monday night with about 40 miles of range, I plugged in and started the charge (usually on schedule). Car started charging, but not pulling the full 40 amps (only up to 15 amp).... and then after about 45 miles stopped charging at 53 miles of range (Charging complete). I unplugged, replugged, rebooted main screen, nothing would convince it to charge more. Car headed to service this morning. :(
  2. ckessel
    ckessel Active Member
    Sounds like an SC visit is in order. :(
    I suspect correlation rather than causation. Someone asks this question after nearly every software update. Some quantity of folks will have a charging issue at some point and statistically some percentage will happen to develop the problem shortly after a software update even though it's probably nothing to do with the update itself.
  3. drbradfo
    drbradfo Member
    Portland, OR
    Problem turned out to be a communication issue inside of the battery pack. SC replaced it with a different battery and sending old one back to the factory. Nothing to do with FW6.0, as far as SC could tell.
