Charging keeps restarting
mswlogo
5,965
4,572
MA, NH
Did a short trip last night and plugged in when I got home. Probably 40 miles and a couple hours to charge. Set to 80%.
This morning I wake up to a clicking noise. It’s the relay in Tesla Wall Connector Gen 2 clicking on and off. This install is like a month old.
There was no errors or warnings. I think it was just topping off and only was adding 2 miles.
It was cold last night, but not that cold (28F). So I bumped it up to 85% and it’s charging fine.
dmurphy
Woof.
Dec 7, 2018
3,341
4,549
New Jersey - Morris County
Has this reoccurred? I'm having exactly the same issue. In fact, brought the X in to be checked out because I was getting warnings on the display. They can't find anything wrong - think it might be my wall connector or electrical circuit.
Problem is, I have two wall connectors at home on separate circuits. The X has done the same thing on both.
Never on the 3.
So bizarre.
ModelNforNerd
4,078
3,890
Ayer, MA
Never on the 3.
So bizarre.
Same. I've had an older S, a P3D, and now an X, all have used the same gen 2 wall connector, and the X is the only one to do this. Started in late October with 2020.40.8
Reactions: dmurphy
mswlogo
5,965
4,572
MA, NH
Yes, still does it.
If I turn the car down to 20 Amps it won’t do it. And if I do that, after it gets going I can turn up to Max which is 32 A.
I think it has to do with battery heating when it’s cold. It’s like it’s too much inrush and trips something. By setting it to 20A and cranking it up it spreads the inrush out.
I did go through and retorqued everything. Couple places got 1/4 turn tighter. But no change.
If I drive in with a warm car it will start fine at 32A. If I let it sit over night and start charging ( which is not my routine) it goes into the loop. It gets into the cold battery loop on its own if I just leave it and it tries to top off in the middle of the cold night it also loops.
Reactions: dmurphy
dmurphy
Woof.
Dec 7, 2018
3,341
4,549
Yes, still does it.
OK guys, you’re both making me feel much, much better.
I brought the X in for diagnosis and pick it up tomorrow. I’ve been feeling stupid all weekend because the end result is “no trouble found — insert the charging handle harder, dumbass.” I can admit a few times my wife’s half-plugged the car; she treats it like the Model 3 (which plugs in like buttah.) but the relay clicking on/off/on/off has happened randomly starting yeah — about in October.
I was starting to wonder if I had a loose ground (I don’t. Checked with the multimeter - all good) or loose wiring somewhere. Checked at the breaker and the WC’s. Nada.
And now, tonight, the loaner S (it’s a ~2013 85) also had issues with the connector relay clicking on/off/on/off. It’s on 2020.36.x though. Something changed somewhere and I think the cold is exacerbating it.
mswlogo
5,965
4,572
MA, NH
For the record a multi meter is fairly useless for testing stuff like this. You need to pull current through any high voltage AC to really test if it’s right. But your ground is probably fine too.
Glad it’s not just me too or the new Wall Connector (Gen 2). Looks like they introduced a bug. I have a 24A UMC at another location (plugged in there now). Curious if that will do the same. I plugged in with warm battery and it’s charging fine.
Ooh I might not hear it looping with UMC. That’s not good. The Wall Connector was bolted to the house and I’d hear it clicking in the middle of the night when it decided to top itself off.
Again it always works if the battery is warmed up.
SSedan
2,948
2,306
Greenville Wisconsin
I had this happen a few weeks ago 2014 P85 gen 2 wall connector.
Rebooted the car and flipped the breaker off/on and has been fine since.
It sucked down tens of miles of charge, probably did this from 1am schedule charge till I caught it 6:30am when I took the dog out and heard it. Was cold enough weather battery heating would have been involved.
djillusion
214
87
Chicago
It’s most likely the Gen 2 charger. Check all wires and connection going into the charger.
long story short for me: Somewhat similar issues for me and my Gen 2 burned out.
dmurphy
Woof.
Dec 7, 2018
3,341
4,549
long story short for me: Somewhat similar issues for me and my Gen 2 burned out. View attachment 615487
Sorry to see this but I can't imagine all of us having a loose conductor all at the same time. Something else is up ...
And for the record - I have two wall connectors at home, and the Model X does it on both of them. Model 3 -- no problem.
Reactions: VikH
davezforce
IG @davezforce
Jan 18, 2017
495
240
NJ
Happened to me a couple weeks ago. Turned the breaker off and cleaned the charge port and handle contacts with wd40. Turned on breaker and haven’t had problem since.
Reactions: VikH
Freeseframe
7
Iowa
I have a similar issue but only with scheduled departure. If I use scheduled charge at X:00 it will work as intended. I’ve reset everything and even shared video with mobile service and they shrugged their shoulders and said “must be a bug” but said save the video in case this is some bigger issue. For now I’ll keep using scheduled charge start time as that still works as intended.
VikH
941
770
Midwest, USA
I have the same issue. Only happens with Departure Charging. Has to be a software bug from the car.
ModelNforNerd
4,078
3,890
Ayer, MA
normally I would agree, BUT:
when my car is plugged in and awake, and I manually start a charge from the screen or the app, it works fine.
when my car is asleep, and I have scheduled charging set (i don't use scheduled departure) is when I run into these problems. it will click on and off until I wake up the car via app....as soon as I do that, it will begin charging.
Big Ike
123
130
Arizona
I am having an issue with the amps tapering with both of my Gen 2 wall units. I have a 72 amp charger on board, an 80 amp circuit, so the vehicle only gets 64 amps. When I plug in I usually see 64 amps as the denominator, but on occasion will see 6 amps on either unit. I'm on a TOU plan so charge after 9pm. About once a week the vehicle has not fully charged - I use 90% as my daily ceiling.
I'm going to give @davezforce's WD40 cleaning solution a shot and will report back.
bitrover
63
43
Eindhoven
Same Issue here on a European Model X.
Took delivery last week.
I have 2 chargers (1 Tesla and 1 openEVSE), both chargers show the same pattern.
Charging works fine when the car is awake, leave one door open and charging starts fine.
When the car sleeps and charging Is started using the app or using delayed charging then the clicking issue starts.
Rebooted the console and turned the car off using the service menu seemed to resolve it for now.
_jmk
313
214
Finland
It's a configuration bug in the latest releases according to Tesla. Tesla claimed to me that they tuned my config and it should be fine now, shall see today.
