I have had my m3 for a little while now and have been charging at public stations. For example, a 6.6kw chargepoint locations but when I plugin, it maxes out at 30 amps and about 200 volts which results in 6kw, not 6.6kw and a charge rate of 22/23 mph.
I am not able to change anything but the max amps which I thought would be 32 on this configuration too but why am I not getting the full 6.6kw out of the charger?
I have also been on a destination charger rated at 16kw but again, it maxes out at 48amps and 200 volts which results in a 37mph charge rate. I am thinking this should be higher too.
Is there something I am not doing?
