It's a transformer thing. Residential is 120v/240v Single phase center tap. The transformer primary is connected between two of the phases, and the secondary is center tapped, and produces 240V. This gives you two 120V legs, 180 degrees apart.
Industrial/Commercial run three phase (correction have 3 phase run to them), so you get 120v/208v (or 277/480)
Transformers aren't cheap, so as the old adage goes "Run what you brung". If you got 208, run 208 unless you NEED something else.
