Charging noise normal?
Discussion in 'Model S: Battery & Charging' started by smilepak, Jul 19, 2015.
  1. smilepak
    smilepak Active Member
    Eastvale, CA
    I got 40 miles range left and at the Super charger. e955113b5f6554b13b5c3cfeaa87e165.jpg
    Is it normal to sound like a 747 when charging?
  2. andrewket
    andrewket Well-Known Member
    If you're charging at lower SOCs, especially if it's warm out... Yes.
  3. smilepak
    Eastvale, CA
    It's raining outside 71 degree and I just drove 100 miles to this station.
    What's SOC?
  4. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    SOC is state of charge (% charge)
  5. smilepak
    Eastvale, CA
    Thx.
    By the, what's the health risk sitting in the car while it charge? Long term glowing? Lol
  6. S4WRXTTCS
    S4WRXTTCS Well-Known Member
    Snohomish, WA
    Ha, when I was charging in Springfield, Oregon (I believe it was there) it the fan noise was ridiculous.
    But, then I realized the car was sitting above a man hole cover that was massively warm.
    So all the air under the car was really warm. I've never seen the air above a man hole cover so warm, but the heat was definitely coming from it. Some aliens must have been down there.
  7. kuttakamina
    kuttakamina Member
    DC
    The first time I plugged in my car in my garage, it made a faint 747 like sound. It seemed to come from the frunk area. I was like .. wow what the hell is that! Anyway, I ignored it, car seems to run fine.
  8. spottyq
    spottyq Member
    Belgium
    The car A/C is working hard to cool the pack. (Charging, especially at high power (=supercharger) will cause heating of the batteries.)
    The radiator of the car are in the front of the car, they vent to the front and in the wheel arches.
    It completely normal, and has already been mentioned multiple times on the forums.
  9. mwulff
    mwulff Member
    Danmark
    As others have stated it is completely normal. The car has a radiator on the drivers side in the front. This is what cools the battery pack when super charging.
    I have seen examples of a supercharger site where all the cars had the 747 sound on, it sounded like being in a windtunnel ;)
  10. mibaro2
    mibaro2 Member
    Georgetown, ON
    I found that charging at the newer superchargers make more sound than at the older ones (which charged at a lower speed).
    At one point my steering wheel seemed to vibrate.
    I was at a low SOC with about 25km left and it was warm outside.
  11. mknox
    mknox Well-Known Member
    Toronto, ON
    My car has never, ever under any circumstances made any noise when Supercharging. Other cars around me sound like jets ready for takeoff. I've made an enquiry at my Service Center and they said they'd pull logs. They said with the lack of any warnings I might see on the dash, the pack is probably just not hot enough to warrant a/c use. Fair enough, but I wonder what makes my car so much cooler than everyone else around me?
  12. One Gear
    One Gear Member
    Australia
    The last couple of times I have supercharged and been with the car, a lot of hot air has been venting from one wheel arch (left side as I recall) but not much at all has been venting from the other wheel arch. Is that normal? Should hot air be venting from both wheel arches?
  13. bollar
    bollar Disgruntled Member
    Southlake, TX
    Maybe it's an A pack benefit.
  14. Galve2000
    Galve2000 Active Member
    NYC
    I was taken aback by all the noise the 1st time I got out of my car at a supercharger... thankfully there were 2 other cars charging up at the time and they sounded the same so I figured it was normal.
  15. spottyq
    spottyq Member
    Belgium
    I'd guess the radiator design is symetric (ie. should vent as much in both wheel arches), but don't know for sure. (I don't have a MS.)
    Someone else will have to chime in on that one.
  16. jbcarioca
    jbcarioca Well-Known Member
    You're in Toronto, right?
    In warm climates the BMS set off the battery cooling system and often we have the a/c running too. The combination is indeed noisy, but there is nothing wrong. In cold weather you'll rarely if ever hear those sounds, the hotter the weather and the longer the charge session the more the batteries heat and the more cooling they demand. Two choices exist IMHO:
    1. Ignore it;
    2. record it in order to prove that EV's can indeed be noisy.
  17. mknox
    Toronto, ON
    I wondered if it was an artifact of the slower Supercharging, but I actually had a Sig owner with an A-pack tell me that his car's a/c does indeed kick in when Supercharging.
    - - - Updated - - -
    Yeah, but in my case, the car is perfectly silent even when it is very hot, and other cars are humming away like mad.
    - - - Updated - - -
    Yes, and this is what has me concerned. Mine seems to be the only quiet car. Tesla says if my battery was hot, I'd get some sort of warning on the dash, but how would I see if if I'm outside the car?
  18. WarpedOne
    WarpedOne Supreme Premier
    Slovenia, Europe
    That *may* indicate a problem with you car. It may not explode immediately but there might be some accelerating degradation happening to the battery.
    You need to talk with SC about this.
  19. mknox
    Toronto, ON
    Done. In discussion, they don't see it as a problem, but I do have an appointment booked.
