"Charging Problem" error message, unable to charge
Oh cool, thanks! We never found what you found, nicely done! I rescind my previous statement that the connectors are expensive to find!
By the way m0rph, how is the car?
I thought of another possibility! (depending on what's going on now)
I doubt that I did anything wrong to the connectors. No tension was on the cables and no rough setting down of the PEM. And I re-checked those connectors at least twice.. But never say never..
Today is day 8 in the Service Center, and they are still trying to figure out what's the cause of it...
hey M0rph, I saw in another threat that sold your roadster.
What happened ?
Did the SeC ever found the root cause of your issue ?
I would love to hear the full story, might be usefull for other roadster owners here in the future
What happened ?
PEM swap at my cost... It's actually still at the SeC waiting for this to happen. They don't seem to be in a hurry though.
When finally repaired, it will be shipped to Finland..
I try, sorry, whoever moderates here is a bit overzealous about keeping me quite... I've been blocked from messaging...
I doubt this'll make it up but email me at S C 8 at gruber dot com (hoping the spammers like my boss don't grab that format and use it! Haha)
I ended up in San Francisco a couple weekends ago based on this logic! Depending on access to parts...
m0rph; Another possibility is that when you had the PEM out you damaged one of those connectors on the bottom, there are 4 and each of them is quite finicky, very easily broken, if you don't set the PEM down just the right way you may have damaged one; they are also tough to find parts as molex only sells them in manufacturer lots of about 1,000 units at a time... We have a few, not many...
ElectricLove - will you do a PEM fix in Connecticut? My Roadster #1291 will not charge and its either the fuses as noted above, or something bigger. Drives but cannot charge. Luckily it died after I drove it only a short distance fomr full SOC. Now at Tesla shop waiting for their diagnosis.
