With the lack of sunshine lately, I have been using public chargers more. The one id like to use is a 50kW DC combo but comes up with an error within half a kW charge if I try to charge from between 20 and 85℅. But only seems to apply to M3LR and M3P as the SR charges normally. However, I can only get 40kW peak power. So I usually end up using the type 2 AC 3 phase on the same machine, rated at 22kW but I only ever get 12kW at 16a. I've switched to another non tethered charger this morning also rated at 22kW 3 phase and still only charging at 16a and 12kW. I'm at 30% battery do should be charging at park rate. Does my car have a problem?
Why is it not charging at the rated output of the chargers? I have no option to increase the charge current above 16a but can reduce it. 12kW is still almost twice as fast as I can charge at home and it's free. it's just a pain being at a charger when I could be doing other things.
