Charging rate on Clipper Creek LCS-25
Discussion in 'Model S: Battery & Charging' started by TomServo, Jun 17, 2018.
  1. TomServo
    TomServo Member
    Belleville IL
    #1 TomServo, Jun 17, 2018
    I have an Clipper Creek LSC-25 installed on a 30 amp circuit (with 25 amp breaker) in my garage for my Volt. Have had it almost 5 years. It's bullet proof. I know it's max output is 20amps, but obviously my Volt won't pull that. I know I get about 11MPH.
    A military buddy and his wife will be spending a day with us on their cross country trip in their S85 and I was wondering what sort of charge rate they will get when they plug in. I'd like to send them on their way with a full charge the next morning.
    Thanks in advance.
  2. ucmndd
    ucmndd Well-Known Member
    240 volts x 20 amps = 4.8kw, which is about 14 miles of range per hour on a Model S. Depending on how much charge they arrive with, an overnight charge should get them close to full. 10 hours would add 48 kWh.
  3. TomServo
    TomServo Member
    Belleville IL
    Awesome, thanks for the quick response.
  4. trm2
    trm2 Member
    CLE
    I will confirm those numbers. I have the same clipper creek, same ‘17 Volt, but a 75D instead of an 85.
  5. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    Sorry, if you have a 25 amp breaker, you don't have a 30 amp circuit, you have a 25 amp circuit.
  6. tga
    tga Supporting Member
    New Hampshire
    I charge at 20A with an OpenEVSE on a 25A circuit at my lake house. My P85+ adds 5% per hour, or around 13mi.
    This matches the rate for a 25A circuit shown in the table here (scroll down): Home Charging Installation
