Hi, I own a model 3 and live in a condo that has underground parking. The only outlets that are available for charging are in the storage closet next to my parking spot. The parking itself has like 15 foot ceilings and the outlet that is setup in the closet is this exact model Leviton Porcelain Lamp Holder with Pull Chain and Outlet-R60-09726-00C - The Home Depot
So I able to ask the maintenance guys to use their ladder to run an extension cord of this kind RIDGID 25 ft. 14/3 Outdoor Extension Cord-657-143025RL6A - The Home Depot to be attached to the outlet so I could start charging the car. Now the car charges at only 9/12 amps and stays at around 102-104 volts, which is pretty low but it still charges at 3 mph. I was able to plug just the adapter directly to the car and it still only gave me 9/12 amps with the notification that an extension cord was being used. Anyway if I kept everything as is and just used to charge with the extension cord at 9 amps for constant use; would I be running into any risk of the outlet starting on fire or the cable? I thought since its only draining at 9 amps and both outlet and cords are rated at 15 amps I would be okay, but I rather get a 2nd opinion from anyone here.
Thank you
PS I don't have an option of installing any other outlets in there, everything has to stay as in the parking garage as it's not allowed by the management
Thank you
