1. Why does supercharging show mi/hr estimate, but charging from a standard outlet or HPWC does not show this info?
2. Why can’t I select a higher charge current on some circuits? For example, I charge at work using an outdoor 110v that uses a 20A breaker, but I can only select up to 12A, despite nothing else tying up the circuit. I used to charge my LEAF with an adjustable EVSE set to 16A and never had an issue. And being a commercial property, you would think the wiring and circuit quality would be good enough for more than 12A...
