DarkMatter
Later in that article they talk about it as being a rather small change, something in the territory of a 10% restriction. It seems people with the substantially slower rates have something entirely different going on.
A FLIR image of the condensers while the system is screaming might shed some light.
Thanks for the Tag Here's some Thermals ^v^
Huh. Bend seems like a fairly new one, opening in June 2016. I'm surprised the cables/handles are considered that old and were having problems already.@TexasEV, not sure if you were asking me.... But I was in Bend, OR when the cable swap happened.
I have a lot of experience at this supercharger and prior to the new cables, I would consistently see low charge rates...sometimes as low as 40kW even with a low battery charge. After the new cables, every single stall gives me >100kW.
It doesn't just need to be the car thats hot, it can also be the supercharging cabinet. It also seems to be completly random. I get the same issue here. Move over a stall and it's fine, go back to problem stall the next day and it's fine, or the fast stall and it's slow, move to the problem stall from the day before and it's fine again....
59% - 74 KW
60% - 72 KW
61% - 70 KW
62% - 68 KW
63% - 66 KW
64% - 65 KW
65% - 64 KW
Got distracted for a minute or two
67% - 60 KW
68% - 59 KW
70% - 58 KW
71% - 56 KW
72% - 55 KW
73% - 54 KW (2 KW more than before)
74% - 53 KW
