charging slowed to a trickle
Acps110
61
206
Charleston, West Virginia
You can’t get 6 kW from charging via 120 volt.
You have changed your display from miles to battery percentage. You were previously getting 6 MPH charging, which equals about 1 kW. Same super slow charging rate, just displayed differently.
As noted above, with 120 volt charging it can heat the battery or charge it, but not both at the same time. If it is below freezing for an extended period of time while plugged into 120 volt, you may see the battery state-of-charge decrease as it is not able to keep the battery warm enough to allow charging.
JulienW
2,521
2,738
Atlanta
120V * 15A = 1.8kW theoretical MAX (and would trip the breaker). So 1kW through a cord and rectifier is about right.
In order to get 6kW charging you would need 240V at >30A.
Reactions: Rocky_H
Gasaraki
1,374
939
Syracuse, NY
I charge my Model 3 using an ordinary 120 wall outlet. Previously, charging was taking place at 6 kw, according to the app. Recently, using the same outlet, the charging rate has slowed to 1 kw. Does anyone know what is going on here to cause such a slowdown?
LOL, a no point in this universe was your 120V/15A outlet giving you 6KW of power.
Rocky_H
5,848
6,684
Boise, ID
I've seen people make this units mistake in a few threads here on this forum. This thread reads almost exactly like yours:
110v Charging Rate Changed
As @Acps110 correctly figured out, you didn't pay attention to the units of your charging speed number when the number changed. You were not getting 6kW from a regular wall outlet--that's not possible. That was 6 miles per hour. When it switched to about 1, that was 1 kW, which is about the power level of that outlet. And yes, that toggle does come from if you change the display settings from showing "Distance" or "Energy".
Reactions: jjrandorin
mswlogo
5,965
4,572
MA, NH
Hmm, maybe display is different on Model 3.
But both the App and Screen in the Car show BOTH watts/hour AND miles per hour charge rates. Maybe there is another spot I’m forgetting that shows one or the other.
MarioAndretti
New Member
Feb 15, 2021
3
7
Illinois
I'm not near the car right now and I'm done charging so the Android smartphone app doesn't tell me anything right now. But I'll take a closer look at the screen next time I'm in the car. Thanks.
JulienW
2,521
2,738
Atlanta
I get 8 kW @ 32A with a 240V 14/50, so 6kW would require about 24A. But yes, impossible to get with a 120V 15A outlet.
240V x 32A = 7.68kW and 240V x 24A = 5.76kW absolute theatrical (not practical or sustainable) MAX. That is just math and physics.;)
