Charging speed to 100% dramatically slower!!!
sorka
7,637
5,665
Merced, CA
Here's an elegant idea for Tesla to deal with degradation. Slowly raise the 10% top buffer invisibly to 9%, and 8% ... as the battery ages. Keeping the advertised range true and steady for longer, at the expense of now slowing the charge times with more pronounced taper.
I suspect they're already doing this. Cars with newer batteries that hit 0% drive longer long than older cars that hit 0% which probably means that as the miles pile up, they're dipping into the anti brick buffer to make the degradation not seem as bad.
sorka
7,637
5,665
Merced, CA
If you can't charge are
If you can't charge that high why do you think it should be able to sustain regen that high?
Sustaining regen never came into this discussion. Coasting downhill 99% of that 30 mile leg was not doing any regen at all. The only regen was slowing down for corners or coming to a stop at the light on the last grade just entering Sonora.
After that, regen was limited to 10KW for the next 60 miles home even even though the battery remained cool in the 80 to 85F range.
The point is that the behavior has changed dramatically. The point of this discussion was to suss out whether it was related to software changes or degradation.
sorka
7,637
5,665
Merced, CA
And they will price it to match. Sounds like a good idea, but until the degradation happens, your carrying around a lot of extra battery and getting no benefit.
Actually there would be a fairly large benefit as charging and discharging in a narrow range of the batteries total capacity results in less degradation in a non linear fashion. For instance charging from 0% to 100% causes far more degradation than charging 30% to 80% twice.
sorka
7,637
5,665
Merced, CA
A new first this morning. Plugged in last night at 65%. Timer was set at 4:00 am. Temperature was mid 65F in garage this morning(we had a heat spell yesterday).
Normally, 65 to 80% would be done in 36 minutes at 80 amps. But this morning it was still going at 7:50 this morning when I walked out into the garage. It was at 79% and 5 amps and said "calculating remaining charge time". There was no error displayed at all and the charge port was pulsing green.
sorka
7,637
5,665
Merced, CA
Me too, but then the charge port is yellow and you get a an error on the dash telling your it's not plugged in right.
There was no error and the port was pulsing green.
sorka
7,637
5,665
Merced, CA
If it's pulsing green AND there's no error on the screen then it thinks it's seated properly and won't reduce charge for that.
thefortunes
1,073
1,266
Wisconsin
Do you use TeslaFi (or any other logging app)? That could show you what happened over those 4 hours.
Something doesn't sound right, I hope (one of your) charger(s) isn't failing (I had to replace mine about 18 months ago).
sorka
7,637
5,665
Merced, CA
Used to use visible tesla until it stopped working several years ago.
I have TeslaFi but I don't pay the $5/month logging fee.
sorka
7,637
5,665
Merced, CA
OK, so I figured what heck, I'll try it for a while. I selected $5 / month subscription choice and it charged me twice for $5 plus once for $50!!!
LCR1
1,322
970
Houston
Nope, flashes green when I plug in then later tells me there's an issue and limits charging to 16A. I'll get wasted tonight and do it again so I can take a picture.
sorka
7,637
5,665
Merced, CA
I've had a limit from 32 to 16 amps on a level 2 charger where it says the charge was reduced and shows a new maximum of 16 amps on the dash. But there was no such warning and it showed 5/80 on the dash, not 5 out of something reduced from 80.
bhzmark
3,420
5,161
For further diagnostic info, try turning on the ac heater remotely when plugged in and see what happens. And also check range mode is off.
sorka
7,637
5,665
Merced, CA
Range mode is always off. I'll try that if I can reproduce it. I expect that whatever it's charging at it will increase by the amount that the heater requires.
bhzmark
3,420
5,161
Here's a recent comparison with my p85dl battery:
And from almost two years ago:
Reactions: sorka and MP3Mike
