lx3h
Charged.hk's Director of Education
The following is the Government's strategy related to this:
http://www.legco.gov.hk/yr13-14/english/hc/sub_leg/sc10/papers/sc100305cb1-1027-1-e.pdf
Mark, so this is good news, or good olds?
Promoting EV while having 13A charger in place is hilarious. Why still bother in 13A?
One of my friend was seriously considering a 60KW MS, but after knowing it takes 40 hours to fully charge the car, he pull out. It just doesn't make sense in anyway.
Does anyone know if we will suffer the same single phase only charging issues that the Europeans are having now? Im not that up on it, but since we seem to be getting the European plug i assume we are getting the associated problems?
I think this is the most relevant thread. Basically, in some situations with public single phase charge points, the car can only charge at 3.6kW with single charger and 7.2kW with dual charger even when it is designated as a higher power charging station. The problem seems to come from the fact that the maximum input is 16A per line per charger. If the Type 2 plug only has power on the L1 pin, you get the 3.6kW and 7.2kW limits. If you have a home "wallbox" you can wire L1 to all three pins L1/L2/L3 and the chargers will draw current on all three pins. I recall some disagreement about how the pilot should be set in this situation so you're not pulling 3X what the circuit can handle. Long story short, go for the dual chargers because you don't want to be limited to the equivalent of a HK wall outlet on a high power single phase station due to some compatibility problem.I heard of problems in Norway (suspected to be Norwegian power supply compatibility issues). Do you have a reference to other issues?
I think this is the most relevant thread. Basically, in some situations with public single phase charge points, the car can only charge at 3.6kW with single charger and 7.2kW with dual charger even when it is designated as a higher power charging station. (snip) Long story short, go for the dual chargers because you don't want to be limited to the equivalent of a HK wall outlet on a high power single phase station due to some compatibility problem.
HKEV confirmed they can install 2 x 32A 3Phase chargers at my place, what I will get done asap.
Out of interest, I was given a data sheet by Tesla today and it says that,
Single phase, 200-250 Volt, 32 Amps AC supply, 50 Hz
IEC 60309 230V, 32A, 6h, 2P+G, 3 pin blue outlet
is required, also,
To take full advantage of your Mobile Connector, work with anelectrician to install at a 240 Volt, 32 Amp, single phase outletwhere you plan to park your Model S.
To ensure uninterrupted charging at full power, the circuitbreaker should be rated for at least 32 Amps.
from this document,
posted on another forum, it suggests that all we can do in HK is to charge at 35km/h regardless of how many chargers we have.
Can any experts here shed some more light on this? Im getting the impression that Tesla HK doesn't really know themselves and I would like to know exactly what I am getting and what I need.
This is the same as in USA where they recommend a NEMA 14-50 outlet (240V 1-ph 40A continuous). The Blue outlet is the best solution for the Mobile Connector and adapter that is provided with the car. You could also use the 3-phase Red socket, but I'm guessing Tesla will charge extra for that adapter.Out of interest, I was given a data sheet by Tesla today and it says that,
The table clearly shows that there are options to charge more than 35km/h. The Mobile Connector can deliver 50km/h if you use the 3-phase Red plug. If you install a Type-2 "Wallbox" fed by 3-phase 400V 32A, you can get 100km/h with Dual Chargers in the car. This is equivalent to the Tesla High Power Wall Connector in North America, but they have not yet offered one for the Type-2 inlet cars. The charging rate will be slightly less in HK than the EU table above due to 220/380V vs. 230/400V in EU.To take full advantage of your Mobile Connector, work with anelectrician to install at a 240 Volt, 32 Amp, single phase outletwhere you plan to park your Model S.
